"Volume knob not working on my onkyo tx-ds656"
replace the volume knob but check the volume control IC first such as voltage and whether an analog signals come out by an oscilloscope.
and " lost remote " Check if the onkyo remote is working, by:
(1)point a mobile or a smart phone camera at an onkyo remote control.
(2)Don't take any photo.
(3)Now the remote picture is on the mobile or smart screen.
(4)Press any remote control key.
(5)White flashing light can be seen if remote is ok.
(6)If remote is fine, replace the remote senor on tx-ds656 with same part number.
SOURCE: Onkyo TX DS575x reciever remote problem
You might try this replacement
http://www.remotes.com/remotes/servlet/rs?a=gmi&uid=11953114154530&smodel=TXDS575&brand_pn=ONKYO_TXDS575
SOURCE: No Sound - LCD Volume says 99
Found a solution that works. Power down the receiver. Unplug it from the wall. Wait 10 minutes. Plug it back in and power it back up. Worked like a champ to fix this exact problem with my TX-SR601.
SOURCE: cant find universal remote code for the onkyo tx-sr605
Your onkyo receiver and remote controller only decodes 4 digit codes so what you have to do is to call the manufacturer of the remote controller it self and ask for the hexa decimal codes for their remote. They should provide it to you coz they're the ones responsible on doing that.
SOURCE: Onkyo TX-SV 727 PROTECT mode
Generally, this happens when there's a loose connection somewhere, either internally, or with the connections. It usually happens when the volume's too loud, and it tries to protect itself.
I'd suggest you unplug everything from it, check all the speaker wires, and then try turning it on, without any devices connected to it.
If it works, turn it off, and reconnect devices, one by one. That should fix it.
If not, it's likely that there's a loose solder inside, and it needs to be sent out for service.
SOURCE: Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
time warner does not supply the codes. the equipment manufacturer supplies the code to the remote makers
