SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
SOURCE: I want to find a operator/owners manuel with a
get a hold of miller theyll be more than happy to help you,and turn you on to a owners manual.hope this helps jojogunn.
SOURCE: i have a solar mig
I found the solution to my problem. Willyboy695, My machine was working fine, but the wire was HOT all the time. Not a good scenario..and dangerous.
I contacted USAWeld on ebay. Jeff Nolan put me onto the problem, my RELAY, which is a solid state item, had gone bad. I replaced the relay, and the welder is up and running as it has for over 20 yrs. The relay, CRYDOM D2440 was replaced, and the unit on your machine may be a different number, but give this a try.
Jeff Nolan can be reached at:
Jeff Noland
HTP America, Inc.
1-800-USA-WELD
www.usaweld.com
I hope that helps.
BobsHemi
SOURCE: spool gun not working
Was it working before?? If so check switch on gun/relay in welder and connections. If not it is not connected properly/bad relay/ gun switch/ or bad spool gun.
SOURCE: Hobart Handler 175 230 Volt Mig trigger
also do you hear any clicking when you depress the trigger?
You should. If nottry to jump the trigger wires inside themachine right where it goes out to the "gun"wires? worksnow? problemis in the gun cord somewhere.
Still not working? CHeck the contactor. SOmetimes a boxelder bug will get inthem and prevent them from working, or the contacts fry themselves.
