All msgs going out have to go through a message center. You must call up the helpline of the service provider and as them the message center number and configure it in your phone. Then you will be able to send msgs.
if you want to flash your sony ericsson. you need tools ( software tools box ) for sony ericsson. then you need to some softwares supporting files. then you can flash your sony ericsson.
Hi Fil,
This issue can be resolved only by the sony ericsson service center. As it needs to do flash on the handset. This issue can be resolved by themselves as sony ericsson only has the solution software with them.
Thanks
This is usually a software issue on K series Sony Ericsson Handsets, try using the Sony Ericsson Update Service to Update or Re-Install the phones firmware...
Its available to download from the Sony Ericsson support site if you dont already have it
http://www.sonyericsson.com/cws/support/phones/k770i?lc=en&cc=gb
Remember though if your phone is unlocked, the unlock for these may have been a Flash Patch unlock so you might have to get it unlocked again afterwards...
If you have vmail and no msgs and the only light that is flashing is the light at the top right of the display, what that is flashing for is someone set a msg to your phone from another phone on your system. Try this :
without picking up the handset , dial 43 .
the display should show the ext # that set the msg and an option to reply or clear . press the btn under the display where it says clear and the msg will clear and the light will go out.
