Question about Onkyo Audio Players & Recorders
Having trouble getting streamed music from my PC to an Onkyo TX-NR656 receiver
I have HDMI cable connected from rear of computer to HDMI PC input on receiver. No sound
    Loyalty:
    Visited the website for 30 consecutive days.
  • 130 Answers
First the OS must be win 7 or above; XP does not
support bit streaming. Second, display card or motherboard on board display card must support
bit streaming. Third the software must also support bit streaming.
See photos:
https://m.review33.com/forum_msg.php?db=3&tstart=0&s=&topic=75170724185351&number=9&sort=1
Posted on May 29, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: No video through HDMI section of Onkyo TX SR-805 receiver
My has problems with losing video on HDMI, component, or svideo, this is a piece of you know what!
Posted on Jul 12, 2008
Anonymous
SOURCE: Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Posted on Jan 05, 2009
Anonymous
  • 4 Answers
SOURCE: Onkyo TX-SR705 - No Audio - Flashing HDMI
The posabilities is power amplifier on your reciever is bad,
replays reciever or repair it.More likely this is IC amplifier located on the main board of the reciever
Posted on Apr 17, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: How do I link my Onkyo TX-SR507 to a PC?
It sounds like you don't fully understand the Onkyo's HDMI port assignment procedures.
But why burden an HDMI cable with audio only? Don't you have a coaxial digital or spdif optical output on the PC you could use? That would make things simpler for setup. Just jam it into one of the appropriate audio inputs on the Onkyo.
Posted on Jan 28, 2010
ABRsvcs
  • 4234 Answers
SOURCE: How can I connect my Onkyo TX-SR507 to a PC to play MP3 files
The easiest way is to use a 1/8" stereo to dual RCA cord and connect the output of the sound card to an AUX input on the receiver. These cables are readily available and cheap. You shoul dhave 3 mini jacks on the back of the computer related to the sound card setup.
1) Audio input mic
2) Audio input line
3) Audio output line
Connect the receiver to the audio output line jack.
Dan
Posted on Jan 30, 2010
Unable to connect a blu ray dvd player to onkyo tx-sr605 via hdmi
Not sure what unable to connect means..but I will assume you have the correct cable.
First make sure you have plugged the from the HDMI cable from the DVD play into the IN 1 HDMI port on the back of your Onkyo
On the Receiver
Enter the Setup mode
Select INPUT OUTPUT ASSIGN
Next make sure the HDMI monitor out is set to YES on the Receiver
Monitor out
HDMI Monitor - YES
Next you need to assign the HDMI INPUT to DVD
HDMI INPUT
DVD - IN1
CBL/SAT - IN2
This may be your issue.
Next step would be to verify your television input settings.
Nice receiver!
Best of luck!
Apr 13, 2011 | Onkyo TX-SR605 Home Theater Receiver 7.1...
Has trouble getting input signal
This unit has a defective hdmi board,this is a common problem with this model. The unit is to be taken to a onkyo service center for exchange of the hdmi board under warrenty, if out of warrentyit will cost you several hundards of dollars.
Apr 19, 2010 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 HDMI Input
The problem is the hdmi board in the receiver .they are having trouble with the smd regulator and smd capactors that they are using on the board,they have updated the new boards as i have not got any back when replacing with the new boards. I have replaced at least 35 hdmi boards on this model. If you call Onkyo they will tell you that you have a hdmi board bad and take it to an onkyo dealer.
Apr 01, 2010 | Onkyo TX-SR606 Receiver
1) Audio input mic
2) Audio input line
Dan
Jan 30, 2010 | Onkyo Tx-sr507 A/V Receiver
Jan 28, 2010 | Onkyo Tx-sr507 A/V Receiver
How do I connect a sony BDP-s350 blue ray player to a onkyo tx-sr803 7.1 receiver with the hdmi cable?
Connect HDMI cable from the rear panel of the blu ray player to the DVD/IN digital section, labeled as "HDMI/IN" on the rear panel of the receiver.
Jan 01, 2010 | Onkyo TX-SR803 Receiver
Onkyo605 stopped outputting Video after installing HDAV1.3 sound
If you didnt change any of the inputs going to the onkyo. I would check the input setup. I dont know what input you have your pc connected to on the onkyo, i'm guessing that your using a hdmi cable. make sure you have hdmi selected as your input type not component video or any other. That model doesnt upconvert anything to hdmi. Also some dvi-d to hdmi dont play well wih onkyo.
Aug 16, 2009 | Onkyo TX-SR605 Receiver
Onkyo TX-SR606 getting no sound from HDMI sources on speakers. I have a motorola cable box and a panasonic DMP BD-35K blueray player both attached to the SR606 via HDMI cables (HDMI3 and 1 respectively)...
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Feb 20, 2009 | Onkyo TX-SR606 Receiver
ret4good
Jan 04, 2008 | Mitsubishi WD-73833 73" HDTV
Onkyo TX-SR605 conected to Mitsubishi DLP TV
What I think I did and how I fixed it!
FACTORY RESET ON EVERYTHING!
All you have to do is to do a factory reset on everything, but I thing mostly on your 605, but I would do it on the TV as well. I think what had happened is after I set everything up for the first time, it worked great. As the days when on I started to play with all of the futures the 605 and the TV had to offer. I was turning them on and off to see what everything did. What I think I did was, I turned on something in the 605 that the TV did not know how to cope with. If I had to guess, I think it is the Lip-sink feature (Spelling?) in the 605.
Anyway disconnect everything, look in your manuals of the TV and the 605 to see how to do the factory reset on both. Then turn your TV on. After it does it’s start up for the first time (again), start connecting the 605.
It has been working great for me after I did this. Do not count on help from the people you bought it from or the people who made it. This stuff is so new they do not really know how to fix it.
Robert…
Jan 04, 2008 | Onkyo TX-SR605 Receiver
23 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
