When you start the forklift hyster H7.0FT and engage reverse gear it is coming out of reverse when you rev the machine
SOURCE: vault on automatic gear box on toyota estima enima
Normal reason for this because car is low on automatic transmisson fluid
SOURCE: hyundai excel 1996 automatic will engage reverse
It appears you have a Forward Clutch FAILURE. Replace the trans after you get it diagnosed and verified by a professional technician. By the way, do you have a Check Engine light? If so, what is the diagnostic code? The dealership can scan the system and find any codes which may have been stored in the TCM (Transmission Control Module). If there were any 'Incorrect Gear Ratio" codes, it's most probably the trans itself.
SOURCE: car does not drive forward but works in reverse
Sad to say but your automatic transmission has bit the dust.
2.2td estima enima,the auto gearbox stopt change gear from 3 to 4,can somebody help me please?
