SOURCE: Kitchen Faucet Leak
The stem and washers inside the faucet need to be replaced.
If you Do it yourself the parts typically will cost you less than 20 bucks.
Most plumbers will charge 75 to 100 for this relatively simple Job.
You can order parts directly from the manufacturer, or from a local plumbing supply house.
The faucet may still be under warranty and the parts would be free. Here is ther number for Price pfister.
1-800-PFAUCET (1-800-732-8238)
Testimonial: "As you suggested, the faucet was under warranty and Price Pfister is sending me some parts at no costs. Hopefully, the parts will resolve the issue."
SOURCE: How do I disassmble a jado kitchen faucet with
you have to locate the water shut off valves before you attempt removing the water lines, hopefully they will be located on the lines under your sink, if not you will have to shut the water main off coming into the house. After you have shut the water off and disconnected the lines, look under your sink at the back were your faucet comes through the sink and you will find the fasteners, unscrew these counter clockwise and the faucet will lift out .
SOURCE: REcently installed Danze Ashburyee kitchen faucet
Disassembled hose and realized all I needed to do was tighten the brass coupling to the hose. Problem is fixed.
SOURCE: I have a Danze Melrose
shut the water off take the spout off some times dirt gets between the base and spout clean and if you have a gasket i would change it
SOURCE: Rohl 3810 kitchen pullout faucet leaks under the sink
call ROHL at 800.777.9762 and request a new Cartridge. They will ship it at no charge.
