SOURCE: used the masterbuilt smoker only 5 times???
I just bought a new Masterbuilt Smoker by default two weeks ago I borrowed a friend’s to smoke about 30lb. of Salmon to then can. Ran the smoker every day for three day. ON my last batch the heating element would not work. Talk about Frustrated! The Smoker was only 2 yrs. old.
Knowing I borrowed I felt I had to replace. So online to Cabelas and I ordered my buddy a new smoker and had it shipped. I then found this website... GOT TO LOVE the internet. I saw many other people had the same problem. Found an Answer...
The Problem was one of the connector to the heating element was poor quality and if you don't clean your smoker on a regular basis. The heat and moister caused the small copper connector to corrode and the wire to come loose. I took a wood chisel and cut off all the rivets on the back. I was then able to pull the back off with no damage and access the small box in the lower back. I found the connector. Went to the hardware store and bought a replacement for .75 cents. A pair of wire crimpers and the problem was fixed. I also bought ½ inch Sheet metal screws to secure the back it was good as new. So I returned the smoker to my buddy and kept the new one. When it arrived I saw Masterbuilt has since fixed the problem and provided an access panel to the element and connectors.
Mike in Alaska
[email protected]
SOURCE: masterbuilt electric smoker is brandnew
Had the exact same problems. I took off the electronic control unit and made sure the probe was still connected (unplugged and checked the pins for damage). After reassembling the unit everything worked fine. My guess is that the probe was not properly connected, therefore it was showing 32 deg all the time. Once it was properly connected, the actual temperature showed on the display. Hope that helps.
SOURCE: I have an electric master
Everything you want to know is right here...
http://dadgumthatsgood.com/blog
heatman101
SOURCE: I need to replace the fire rack and bowl for my
I bought a replacement charcoal bowl for a charbroil h20 smoker for $12 on their website. It fits the same but lacks the air holes (I made my own). For the rack, I got some wire cutters and cut my own out of an old steel refrigerator rack. It works.
SOURCE: Master Built Smoker will not over 200 degrees
Hello!
Here you can find manuals for Master Bilt electric grills.
Hope it will help. Seems that there is a problem is with the heating element.
http://manualsbrain.com/en/brands/master-bilt/electric-grills
