Question about Denon Audio Players & Recorders
I have a Denon S-3803 Home Theater System. My problem is that My reomote sensor is not lit and I have no sound coming from speakers
    Loyalty:
    Visited the website for 30 consecutive days.
  • 130 Answers
“My reomote sensor is not lit and I have no sound coming from speakers” For your symptom, not related to remote sensor but to digital decode board such as DIR,DSP and LPF. Download service manual and enter "debug mode" to locate defective circuit(s).
Posted on May 27, 2019
6ya staff
SOURCE:
Anonymous
  • 93 Answers
SOURCE: Denon Home theatre System
If TV has AUDIO OUT and you hook up AUDIO OUT from TV to AUDIO IN on your system, it should play.
Posted on Oct 08, 2007
Anonymous
  • 3 Answers
SOURCE: home theater system connections
Hi
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Posted on Jan 19, 2008
Anonymous
  • 624 Answers
SOURCE: Panasonic home theater system pt760
Make sure you have put the transmitter for the wirless speaker in the slot on the back of the reciever, it is a slim white device that is about 3 to 5 inches long?? and maybe half an inch thick. and make sure it is put in the right way.
Then make sure the wireless speaker is plugged in to the wall outlet.
If this does not work for you it may require being taken in to an authorized panasonic service center. when one part of the wireless system fails (transmitter or reciever) they both must be replaced. they are not interchangable from one panasonic to another.
They have a code in each unit that lets the wireless speaker that came with it only work with the reciever it was sold with.
I have even seen times where the store that sells them swapped the transmitters of two units and then they had two customers very mad at them because the wireless speakers did not work for either person.
Let me know if I can be of any more help.
Posted on Jun 19, 2008
Anonymous
  • 44 Answers
SOURCE: No bass from speakers
go in to your settings an adjust the bass volume
Posted on Feb 17, 2009
ColdTattoo
Don
  • 219 Answers
SOURCE: I am getting static out of all speakers in my
Static could mean a few things.
Magnets on or near (tube TV's) the system could disrupt the signal.
Try plugging the speakers in one at a time with music going to the AUX in. Run through all your settings to make sure that nothing is abnormal.
If it's plugged into a powerstrip, try plugging it into your wall outlet.
201-762-6500 is their main number.
Posted on Nov 17, 2009
Using Denon AVR 2803 as an FM receiver
• Insure that the speaker system is working.
try it on other receiver.
• Check to see if there are headphones connected.
• Check if tuned is lit
Aug 12, 2012 | Audio Players & Recorders
1. Speaker wire broke at connector. Where can I buy a replacement? 2. What is the preset code that will allow this Denon to be controlled by a universal remote?
I ordered a new pair of speaker cables through a local Denon retailer from the Denon distributor in Montreal. $50 +$25 shipping + tax - 2 to 3 weeks they said. Ron
Jan 02, 2011 | Denon S-102 Theater System
"PROTECT" appears on my DENON DHT-500SD
Sounds like a speaker wire is shorting against either another speaker wire or something metallic. Check your speaker wires to make sure they're not shorting (touching). If that doesn't work, I'd take it to a repair facility. Good luck!
Feb 16, 2010 | Denon DHT500SD System
Can't record out from a digital input
It only passes the signal it see's. Digital for Digital and Analog for Analog. Try running a Standard analog RCA from your Cable box to the receiver then try and record. Hope this helps. If you still have an issue, post a comment and I can help you further.
Sep 18, 2009 | Denon AVR-3803 Receiver
No sound coming from subwoofer
Sure we will help you, but you need to check these,
1.Wiring connection from dvd player to home theater system,
2.Wiring connection of a home theater amplifier to speakers,
3.While playing the Original dvd the 5.1 audio you have to manually enable.
and if you still find any difficult please feel free to contact.
Mar 28, 2009 | Audio Players & Recorders
Feb 17, 2009 | Denon AVR-1507 Receiver
Speaker hiss with TV only
Hissing sound caused by input section RCA cables defected grounding maybe loosed or the RCA cables are defected already replaced it with new RCA cables so hissing sound is gone.
Hope it may help you;
Regards;
VOTIT
Oct 11, 2008 | Denon DHT500SD System
Denon surround saying protect on display
Make sure none of your speaker wires are touching, this will cause it to shut down instantly.
Oct 15, 2007 | Denon DHT500SD System
Oct 06, 2007 | Denon S - SERIES PREMIUM HOME THEATER...
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
