Also can we get more damaging winds up to 100 Mph and thunder louder then a regular storm
90 inches of rain is more than you would ever see in a strong hurricane (16 inches is about average).
To drop 90 inches of rain a storm would need to rain at a rate of 4 inches per hour for over a day. Very unlikely to ever happen. I believe that the world record is somewhere around 70 inches.
But yes, most storms with large amounts of rain are usually towering to high altitudes and will involve a clash of opposing warm and cold fronts, causing thunder and lightning (sometimes heavy).
As for 100 mph winds, such winds are completely possible in thunderstorms due to shear downdrafts. The damage is usually localized and often mistaken as coming from a tornado.
Who are you asking? Anyone reading this only has a vague idea of what you need. No specific APP is mentioned and in reality, your question should be directed at the maker of the APP, not on FixYa
90 inches of rain?
SOURCE: I have a 2008 Dodge
Hi, 2possible suggestions that will help you, when dealing with a wind noise it is almost always visible in the affected area by seeing a redich resedue caused by entering dust particles,
you could also use''masking'' duckt tape to seal off all your suspect areas(starting with the r/h section of the windshield) then by trail and error systematically remove piece by piece of this tape untill your noise is located, then you can decide on what to do with the ''leak''
SOURCE: My hp a450n won't turn on. We had a thunder storm
Was the PC running when the storm struck? In that case changing the power supply knows as SMPS which is inside the cabinet needs to be replaced provided your monitor when independently connected to a power outlet, gives a display or says 'no video signal'...................sodeep
SOURCE: Electric windows, radio and interier lights does
There is a good chance that the dome light 12V line touched bare metal during the repair since the door(s) were probably opened, that line would have been 'hot.' I think you only have a blown fuse. If they aren't clearly marked in the fuse box, you may have to check most of them to find the open fuse. If you see none that are visually open, you should use a meter to check continuity.
SOURCE: Fender Stage 100 dsp, solid state amp volume (or power) problem
The Deluxe may have more efficient speakers....which would cause it to sound louder. Also, the EQ settings could play a part in this. If the EQ's aren't set the same there could be a noticeable difference in sound.....usually the mids can have quite an effect on overall amp volume....
SOURCE: high pitch noise when excelarating past 75-80 mph,
Well how short a drive is it.........to get you to go nuts. Is it a high pitched whine? If so look to your right. Is the wife sitting there? If so. That's the problem. Going 75-80 in a 25mph school zone will cause that. And where is the speed limit 75-80 anyway.
It's the radio, btw, install an inline filter to filter out the alternator noise.
