Question about Pioneer Audio Players & Recorders
I have a Pioneer VSX-1022 receiver. I was setting a FireTV to control it. FireTV turned it off but couldn’t turn it back on. I held down the Adv Surround button and the Standby button and it came back on. Seemed to be working fine. Turned it off. Came back later to watch some TV and t wouldn’t turn on. I had to do the Adv Surround/Standby combo again. Turned on. Any idea what is happening here?
    Loyalty:
    Visited the website for 30 consecutive days.
  • 130 Answers
"I have a Pioneer VSX-1022 receiver. I was setting a FireTV to control it. FireTV turned it off but couldn't turn it back on. I held down the Adv Surround button and the Standby button and it came back on. Seemed to be working fine. Turned it off. Came back later to watch some TV and t wouldn't turn on. "
Maybe setting problem. Download VSX1022 service manual to read advance setting if this manual has. If problem cannot solve, just phone pioneer to call for help or send an email to their service department. They will help you. I recommend phone them. Don't be shame when call for help.
Posted on May 26, 2019
6ya staff
SOURCE:
Anonymous
  • 16 Answers
SOURCE: stand by mode
How many times does the standby light flash...b/4 pausing and repeating ?
Posted on Dec 21, 2007
Anonymous
SOURCE: Pioneer VSX-4900S Receiver Connections
I know this is an old post but run front speaker outputs to the inputs on the sub then from the sub to the front speakers. bam!! it should work
Posted on Oct 15, 2008
Anonymous
  • 44 Answers
SOURCE: Receiver Turned Off Won't Turn On
Something had to be hooked up incorrectly.... make sure that all wires are still connected.... make sure they are tightly together.... wires can slip out very easily unless they are soldered together.... if all else fails, it may cost a little more... but if you get it done professionally, it is worth it... make sure that none of the different colored wires touched it. Also... check the fuse in the back of the cd player.... that can also be the issue. :D hope all works well for you.... stereo equipment is not cheap by any means.... Please rate answer well :D .. and good luck!
Posted on Dec 30, 2008
Gustavo M.
  • 30 Answers
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
Posted on Aug 02, 2009
Anonymous
  • 15 Answers
SOURCE: Pioneer vsx-819H: MCACC setup won't display on tv
Its because the pioneer does not display menu options through hdmi. You have to hook up basic yellow composite to monitor out.
Posted on May 03, 2010
Pioneer vsx 52
I am trying to work out which has got the high volume.
If it is the Pioneer then it could be the volume control chip that is faulty. These days volume is no longer determined by a control that adjusts the signal level. The signal is passed to a chip and the volume control setting information is also passed to the same chip. If the chip goes faulty then the volume will sometimes go to max, regardless of the volume control setting. This can also apply to the TV sound as well.
If the sound level is high on other functions of the receiver, such as the radio, then it is certain to be the sound volume control IC.
Nov 10, 2017 | Pioneer Elite VSX-52
I have a Pioneer VSX-1022 Reciever - I get no sound when it is on the "TUNER"
These models have a problem where it is very easy for the tuner pcb to become disconnected from the main pcb. About the only way I've found to fix it, is to take the back panel completely off and reseat the board.
Apr 11, 2013 | Pioneer VSX-1022-K Network Ready Receiver
My pioneer vsx 921 switched off while playing loud. ADv MCACC is flashing and it is not powering on? What could be the problem?
Your unit is locked in protection mode. Hold the advanced surround button and the power button to turn it back on. If it shutdown right away, then you shorted out the amp and need to take it in for repair.
Dec 28, 2012 | Pioneer Vsx 921 K Av Receiver Black
App err
PDF]VSX-D414 VSX-D514 - Pioneer
www.pioneer-latin.com/downloads/xre3077a.pdf
Increase the separation between the equipment and receiver. - Connect the .....AUDIO/VIDEO MULTI-CHANNEL RECEIVER VSX-D514. RCE. VSB. MODE.
Pioneer VSX-D514 Receiver Repair Questions,... - Fixya
www.fixya.com > Forum > Audio & Video Receivers > Pioneer
Recent Pioneer VSX-D514 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
app err Turns on then says amp err. - Fixya
Jan 26, 2012 | Pioneer VSX-D514 Receiver
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
Pioneer VSX-D710S and the message SP off and DTS off message appear and I have no sound. Any ideas how to turn them back on?
The SP off message is the setting for turning the speakers off while headphones are connected on some Pioneer models. If yours is one such model, hold down the RECEIVER button and press the SPEAKER (text may be written above another main function) button on the remote simultaneously and the sound should return.
Apr 01, 2010 | Pioneer VSX-D710S Receiver
Lost remote controller of Pioneer VSX-D506S
You can buy Original Pioneer Remote from HERE for VSX-D506S
Feb 10, 2009 | Pioneer VSX-D506S Receiver
Stand by button flashes but receiver wont turn on
I have vsx-d812 that has an AMP ERR in error menu. the troubleshooting was found to be Q696 and Q697 in the DC prot. area on "C" board, up near front toward diplay in center of c board. You can get access to error codes on VSX pioneer unit by pressing "enter" and "adv. surr." simultaneously for 2 sec. The display should show what error code you are experiencing. I believe there are three diff. error codes. 1) AMP ERR 2) OVERLOAD 3) BOAD ERR (not mistyped) I hope this helps pinpoint error code for ya.
Oct 07, 2007 | Pioneer VSX-816-K/S Receiver
Open Questions:
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
ThaMp3Doctor
ThaMp3Doctor
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
