SOURCE: Light-master garage door opener - re-engaging the motor after dis
The chain and bracket should automatically engage the door's bracket just use the remote as normal,
SOURCE: How do I re-code my Raynor Garage door opener
on the back of your garage door opener there is a colored learn button--press and release-the learn indicator light will glow for a short time usually 30 seconds. within thirty seconds press and hold the buton on the hand held remote that you wish to operate your garage door. release the button when the motor unit lights blink. if you don;t have a light, two clicks will be heard. it has learned the code. procedure will be different for multi function control.
SOURCE: Liftmaster 1/2 HP Garage Door opener won't open or Close
The shaft on these garage door motors are not direct drive systems. You'll have to open up the box to see what the actual problem is. I have had stuff like this happen where a gear just slipped out of place.
http://www.aaadooropeners.com/?gclid=CLH3wt628p8CFVZS2goduwSLYQ
Here is a link for a parts supplier. I don't know your model but it looks like most of the Liftmaster worm screw gears and drive gears are plastic so it's possible that one of them has cracked.
SOURCE: raynor navigator garage door opener won't work in bright sunshine
WOW I NEED TO RAISE MY RATES!!
I DON'T KNOW THE RAYNOR PRODUCT. HOWEVER, WITH MOST OTHER BRANDS THE PROBLEM YOU DESCRIBE CAN BE SOLVED BY SWAPING THE POSITION OF THE SENDING RECIEVING EYES THUS GETTING THE ONE THAT IS BEING AFFECTED IN THE SHADE
HOPE THIS HELPS
SOURCE: I have a Raynor FliteStar
The flite star has an external receiver ( a box located on the back on the motor), Remove the name plate from receiver box and you will find the learn button on a circut board
