Welding Tools Logo
A
Anonymous Posted on May 21, 2019
My inverter welder has oc light turned on and when I try to weld with it, it works for only a minute or two but stops, with the machine display and fan on. bit if I switch it on after a while it works again for a minute or two and just stops working please help me sort tjis machine out
  • Max Muller Jan 18, 2021
    I hope you solved this problem. It can be fixed, but the best option is to get a new welder. A lot of people get just the welder, and they forget about the equipment that should go with it. This is how welding injuries happen. That will not happen to me, I have everything from the welding gloves to the welding table. Having stuff like that makes the job much easier, and it is also safer. If you want to know more about welding tables check out https://afterpaints.com/best-welding-tab.... I was able to make a much better decision about which welding table to get after reading that article.
James Gettemy
Level 2:
Sergeant:
  • Expert 232 Answers
  • Posted on Jun 16, 2019
James Gettemy
Expert
Level 2:
Sergeant:
Answers
232
Questions
0
Helped
131493
Points
821
Sounds like a thermostat is overreacting. If you can call the manufacturer that will help. Good luck.
5 Related Answers
Anonymous
  • 225 Answers
  • Posted on May 25, 2009
SOURCE: Welding machine stops working after a few minutes of welding.
there is probley nothing wrong its called duty cycle.which means that if you are welding long periods or welding at max amps the welder will kickout to cool down.Look on your unit for the tag that tells imformation about your unit.It will show something like 30% duty cycle so that means you can weld 3 minutes at full power before the unit shuts down.
Anonymous
  • 81 Answers
  • Posted on Apr 21, 2010
SOURCE: Lincoln 135 PRO MIG Welder feed stops after a few minutes
1/4" plate with a 135 amp machine is probably beyond it's duty cycle abilites. If you are using a mixed gas, and pushing the max on the settings, it will be cutting out because it is designed to.
You might want to get a higher amperage welder for consistent welding of 1/4"
The 140 Pro maxes out at 5/16" using inner shield wire. and 1/8", or 10 guage with gas.
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Sep 10, 2011
SOURCE: I have a Colossal Tech
O.C is Over Current, this basically means that the welder has been "Overloaded" and it has had to try to supply, too much? current, and it has failed, the "Computer" has "Detected" this and has indicated this error code.
Most often when this occurs some or all of the output semiconductors "Blow" and are damaged or destroyed, however "other" things may also be involved.
The very best thing you can do to achieve the lowest down time and the cheapest outcome will be to engage a professional.
Contact the manufacturer and ask for a referral to an authorised repair service center, when it contact here simply first ask for a "Quote" as to prospective costings and go from there.
If one still insist on DIY, then one simply MUST first obtain a service manual, and work through the troubleshooting steps within, also this manual has all the parts numbers needed to obtain replacement parts. Most often board replacement is the only option, if indeed parts can be obtained from 3rd parties.
Anonymous
  • 1212 Answers
  • Posted on Jan 16, 2012
SOURCE: no arc on my sip 195 mig welder, was welding then it stopped arcing, every thing else works fine,tried it after a couple of hours still no arc. any idea what it could be.Please help.
Internal fuse inline with the transformer output to the gun.
Anonymous
  • 1212 Answers
  • Posted on Jan 27, 2012
SOURCE: Jasic 250F Mig, OC light on, now no power, only fan going.
Check the internal fuse. If that is okay, check all connections and check for continuity across the heavy windings. Transformer may have burned open at a power tap. Or the heavy contactor burned out.
If you do not have a manual, They do not have any douwnloadable at their website http://www.fsh-welding.com If you do need to contact them, I hope your French is up to snuff-
http://www.fsh-welding.com/contact.htm
What mig gun is on a Nevada 220BZ Mig Welder
Nevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder ...
www.ebay.com.au > Industrial > Welding > Welders
eBayNevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder Welding ... Nevada Welding machine; MIG Torch; Earth Clamp; Electrode Holder; Safety Mask ..
I can turn the welder on and it can run all day but when I start welding with in a minute the overheat light will come on and it will stop feading wire. I'm trying to weld on mid temperature.
Have you checked so see if your power cable is the right size?? Is it a 220 or 110? If it is 110 then it will cut off after it gets hot, if it is 220 and the power cord is too small then the machine will be trying to pull more amps than the cord can handle causing it to overheat and shut off.. My husband has been a welder for 20 years.. I'm just passing along what he suggested might be the problem.. Hope this helps!
1helpful
Craftsman 100ac infinant amp arc welder just stopped working ....the fan still runs. anybody know what's wrong with it????
probably over heated and blew the reset button
100 amp welders have a duty cycle ( time in actual welding use ) of less than 20%
that means for welding for five minutes you have to let it cool down for 20 minutes
the lower the amps the longer you can weld for
beware tat the total amperage of the welder does not mean that you can weld for a long time at that amperage
on the plate on the welder is the duty cycle and you have to be aware of it or the machine will shut down
2helpful
3helpful
2answers
SIP 195 MIG welder doesnt work
sounds like your welder has over heated and the Thermostat has come on
wait for 10 minutes and then try again
If that does not work fit a new PCB
Gilmore
4helpful
GIANT 200AMP INVERTER ARC WELDER NO POWER TO THE LEADS
remove the fan from the circuit and try it then, does it weld ok with the fan removed?
Top Inverter Welding Tools Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you an Inverter Welding Tool Expert? Answer questions, earn points and help others
