Re: Got a Campbell Hausfeld gasless 80amp welder. The
If the wire is rusty it will feed hard.May need to replace liner.
Check the power of the feed motor with no wire installed,you're fingers should have to be very tight on rollers to stop movment..
Overheating can cause damage to the internal components of a welder, including the wire feed motor, transformer, and electronic components. It's possible that the high setting on your Campbell Hausfeld WF2050 welder has been damaged due to the overheating.
You may need to check the high setting circuitry to see if there are any visible signs of damage, such as melted wires or burnt components. If you're not familiar with electrical components, it may be best to have a qualified technician or electrician check the welder for you.
Alternatively, it's also possible that the wire feed motor may have been damaged during the overheating. A damaged wire feed motor can cause the wire to feed improperly, which can affect the quality of the weld. You may need to check the wire feed motor to see if it's functioning properly.
In any case, it's important to address the overheating issue to prevent further damage to your welder. Make sure that the welder is being used in a well-ventilated area and that the cooling fan is working properly. Additionally, make sure that the welder is not being overloaded by using the appropriate amperage setting for the job.
Try these or the maker direct. you may also be able to use a liner from another make or model. Look for welding supplies near you, and take the part in.
You could try Canadian Tire where you bought it.
If not there, check to see if the gun is replaceable by contacting the manufacturer through their website..
