Irons Logo
A
Anonymous Posted on May 15, 2019
On my rowenta 1500 w compact vallet garment steamer, the on/off lever won’t click down to keep the unit in “on” position. Help!
Akbar Mughal
Level 3:
Master:
  • Master 540 Answers
  • Posted on May 15, 2019
Akbar Mughal
Master
Level 3:
Master:
Answers
540
Questions
0
Helped
120945
Points
1674
On of switch not working
5 Related Answers
Anonymous
  • 15 Answers
  • Posted on Sep 06, 2008
SOURCE: I have lost my operating
Check out a video manual on Conair Fabric Steamer
at http://www.handbooklive.com/
Click on Appliances category. The video instructions are for GS4 model but it must be similar.
Hope that helps
Anonymous
  • Posted on Oct 09, 2008
SOURCE: conair compact garment steamer
Push down and twist all the way- I had to watch it done on this website to figure it out!
http://www.handbooklive.com/index.php?nav=navprodsBySearch&search=gs4&prodid=13&title=Conair+Fabric+Steamer+GS4&xml=SteamerPlaylist
Anonymous
  • Posted on Oct 31, 2008
SOURCE: rowenta commercial steamer
got this off the manual for the IS 7800
CLEANING
Remove water container and clean the main unit with a damp
cloth. To maintain maximum performance, your steamer must
be descaled occasionally. The descaling intervals will depend
on the water quality and the frequency of use. The unit should
be descaled at least once a year or every 100 hours of use.
For descaling proceed as follows:
1. Unplug the unit and remove water container from main unit
by releasing container lock and pulling up.
2. Fill it with fresh water and shake vigorously to remove any
scale. Pour out the water and repeat if necessary.
3. Purchase a quality decalcifier agent and follow the instructions
of the manufacturer for the proper ratio of the mixture
to water and use.
4. After filling the water container turn it up and down to
descale.
5. Attach reservoir to unit, plug in and switch on.
6. Let the appliance run until the water container is almost
empty and do not steam any clothing with this mixture.
7. Unplug and detach the water container. Rinse it with fresh
water.
8. Fill water container with fresh water and repeat steps 5 and 6.
Note: If after descaling you believe that there is still buildup in
the boiler, repeat steps 1-8.
Anonymous
  • Posted on Apr 10, 2009
SOURCE: My Rowenta Garment Steamer will not steam up.
Ok. This thing is caused by scaling. If the steam generator runs out of water the sensor thinks the tank is empty and causes the machine to go to standby (basically switch off -- orange light comes on). The solution: Open the machine and clean it.
MAKE SURE THE POWER CABLE IS UNPLUGGED BEFORE ATTEMPTING TO DO THE FOLLOWING:
1. There are six screws ( phillips - you will need a long screwdriver). Two of them are hidden under the wheels (just pop off the rollers and you will see the screws)
2. Open the steam generator (there are four screws) and be very careful with the 'O' ring -- you damage it and you can say good bye to the machine. Clean it if you see scaling. The amount of scaling present would indicate how hard your water was. This itself may not be cause of the problem but now that you openend the machine, you might as well as clean it for better efficiency.
3. Disconnect the hose to the steam generator (it has two circlips) and clean it. Mine had hard deposit of scales preventing the water reaching the steam generator.
Re assemble it.
Good Luck
Alex0714
Karam
  • 26 Answers
  • Posted on May 19, 2009
SOURCE: Is there a product to run through a rowenta pro
To start with, use distilled water for steaming. This will prevent calcium build-up. I buy bottles of distilled water for ironing/steaming only. I have never had calcium build-up from using distilled water for ironing/steaming. Do not use tap water!!!
You can buy some CLR (stands for Cacium, Lime & Rust) (can be found at Walgreens, CVS, Target, Walmart, etc.). You can run this product through your steamer to eliminate build-up.
3answers
2answers
How to take hose off rowenta professional garnmet steamer
http://laundry.manualsonline.com/manuals/mfg/rowenta/rowenta_iron_product_list.html
2answers
Why do water drops form om my clothes while steaming
You have a build up of water In the hose. Sometimes happens because the hose is too low to the ground. Try stretching the hose up and tap it and the water should travel back down the hose.
Another reason could be that you are using too much steam for that particular fabric.
Rowenta garment steamer is 9100 lights up but no steam
Look at the manual again maybe theres a button that you have to turn on. Or call the nearest repair man maybe he knows or can tell you.
ROWENTA IS8050 INSTRUCTION MANUAL
Rowenta IS8250 Garment Steamer instructions are no longer available from Rowenta.
3helpful
I have lost my operating instructions, I have a Conair G3 compact garment steamer and want to use it, how do I start. Thank you for your help.
Hope that helps
Top Rowenta Irons Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
