Garden Logo
Chris Williams Posted on May 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Husqvarna ytd 2348 moves slow in forward and reverse
barn2897
Level 2:
Habit-Forming:
New Friend:
  • Expert 153 Answers
  • Posted on Nov 27, 2019
barn2897
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
153
Questions
0
Helped
67372
Points
428
Hi Chris-
I found this link regarding Husqvarna lawn tractor running slow in reverse.
https://www.lawnmowerforum.com/showthread.php/24671-husqvarna-yth24v48-is-very-slow-in-reverse
I also found this link regarding your Husqvarna YTH2348 owners manual (OM) lawn tractor.
https://www.husqvarna.com/ca-en/support/manuals-downloads/
Hope this helps.
5 Related Answers
Anonymous
  • 13 Answers
  • Posted on Oct 21, 2008
SOURCE: AUDI A4 AUTOMATIC SLOW TO
Not overly familiar with Audis but it sounds like either a.) you have an electronic tranny that has a serious bug or b.) there's a problem in the computer of the car itself. What is sounds like is the car is taking a long time to "understand" that you're telling it to move forward. How new is the car? When you push on the gas before the three minutes, what happens?
Anonymous
  • 13 Answers
  • Posted on Jun 18, 2009
SOURCE: golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
Anonymous
  • 11 Answers
  • Posted on Jul 17, 2009
SOURCE: I HAVE HUSQVARNA 1548 RIDING MOWER HYDROSTATIC
You may have a drive belt that is worn or broken. Check the drive belt for slack condition see if it is not slipped off idler pully wheels or the belt tensioner. I had one that was streched out and was very slack on the pully wheels - I had it replaced with new one and was fine to go. There is a device on the back of your tractor to release the transaxle for manual pushing your tractor about with out starting the engine. Make sure the device is positioned correctly for running mode (engine) - There is a symbol on the back to help you know what to do. The tractor manual has good trouble shooting info and if you don't have one, try googling for it with the model number of your tractor - you will be able to download one free to your computer for viewing it.
brado83
Brad Wilkinson
  • 106 Answers
  • Posted on Jan 02, 2010
SOURCE: belt replacement on a husqvarna yth 2348 mower
do you need to know the belt configuration for this mower ive attached a user manual that shows the configuration and all adjustments on the deck and belt...
http://72.3.225.179/manuals/YTH2348-ow-e-96045000502-420798_r0.pdf
Hope this helps
Kind Regards
Brad
mickey813
mickey813
  • 472 Answers
  • Posted on Feb 17, 2010
SOURCE: hi i have a husqvarna ride on lawnmower that moves
sounds like your bely or one of the pulleys are wore out ck the pulleys and ck to see if the belt has sliped off the pulley
Husqvarna M-ZT 61 Hydro Gear 3400 Issues - Reverse Ok, No Forward
Have you checked the fluid level in the left side?
Husqvarna YTA18542 moves forward very slowly
ever check the fluid level . they do not like air .
Can a husqvarna st 224 snowblower be adjusted to go faster in reverse ?
On my 724 I adjusted the cable below the lever on the left side,just loosen the 2 nuts and bring the cable either up or down ,cant remember, I had to fool with it a bit to get where I wanted it, have the blower running and in neutral while adjusting and keep trying her in forward and reverse at full throttle to see after you adjust it, I found that if shes faster in reverse when adjusted she slowed down a bit in forward but keep playing with adjustment till I got it where I wanted it, you have to slow it down going and blowing a lot of snow anyway so didnt mind it a little slower in forward but nice to have it faster in reverse
Husqvarna 2754GLS, Hydrostatic forward/reverse pedal will not return to neutral position.
Parts and Diagrams for Husqvarna 2754 GLS 96043004700 2008 01
I suggest following all the safety procedures suggested in the operators manual first!
ENGINE NOT RUNNING,wheels blocked to prevent being run over, check the return spring ref # 161
My Husqvarna Rider 16c wont reverse - first it was slow in reverse then not at all
You need to check the cable, it is a push pull telescopic style so it is possible to get forward and no reverse, if it was a hydro problem you would not get forward or reverse, there is also timing gears on the forward and reverse pedal, you nee to make sure they have not jumped a tooth as this would reduce movement on the cable at the hydro
My husquarna 2348 keep get slow forward and backup put new belt on it
I have found this on many husqvarnas around this model. A grass build up between the chassis and the second skin above the steering quadrant. lower the cutter deck, get on your knees on the left side of mower and reach up behind and into the back of where the clutch shaft goes into the chassis. The cavity is about 1 1/2 " high. Remove all packed grass.
2answers
2008 Husqvarna YTH 2348 is loosing power...
it has a leak from the head gasket,ive done many with the same problem.pop the head off and change the gasket,also check the rings ect while apart
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
