Response is "there is a Fault they are working on it, but my router has a problem they could not fix it on the phone. They told me a technician will contact me. When??? next year??
No ISP stated, no country even. we are USA.
call them, we are not them.
we don't do service calls,
no modem model and make stated. so Red lights means zero now.
1 week is short time , many ISP take 4 to fix things,
why not change ISP< to one with better service.?
all you can do is keep nagging them.
or post what country, what ISP this is and what name and model of modem you have,
DSL modem.?
Cable modem
SAT box, modem
Fiber.
3/4/5G?
what? even photos work here
Honestly, I’d call and demand a new modem, like next day air or I’m canceling my service. Play hardball...it’s not fun but it’s effective!
SOURCE: Internet connection fails very frequently!
I will try to see if I can Be of some help...But first I need to know who your ISP is. Also I note that you indicated that you try to renew and release you do not show DHCP connected. You should be doing release and then renew, I believe that's what you meant to say? Also please describe to me how you attempted to set up static IP.
Awaiting your info...!
SOURCE: Westell 327 wireless router
I found a solution for this problem. After complaining to Verizon Tech support, I finally got someone to listen. I talked to a Tech that I think was in India, nice lady that walked me through all the line test and finally a modem test. My connection keep dropping through the modem test, which I had a feeling the real problem was. I was told the modem was out of warranty and would cost $59.00 to replace at first, but after calling in so many times this lady sent me a new modem, not a 327W, a 7500. Disconnected the old modem, installed the new one and so far no more dropped connection problem.
SOURCE: Red internet light on DSL router Westell 6100
How long have you had your router and how well is it maintained and well vented? Even the most expensive routers need these two things consistently. Failure in doing this may result in a shorter life span than normal. My guess without actually being there is that it's time to try a new one. If you get the same problem with the new router, take it back immediately and call your ISP for service. It could be possible that there is some phone work being done in the area, and you just happen to be a victim!
SOURCE: the red led light on the internet connection on my
can get on the internet useing my d link dsl 2640r router the red internet light is allways on how do i get on the internet
SOURCE: I have a d-link 615
The router is now acting as a switch and not a router
The Internet line from the modem should go to the Wan-Internet connector of the router. If it doesn't then the router will not show an internet connection just Local connections
If that works as you have it setup, then I would suspect the "modem" you have is also a router.
Go to http://support.dlink.com and get the correct setup information for your router, click the "products" links for the manuals and updates etc. http://support.dlink.com/products/
I have also faced
the same issues which you are facing and my friend told me about "ijinni
technician". I contacted them at www. ijinni. Com. For any issues just
open the website and you can chat with the experts who are Microsoft certified
technicians and will fix the issue itself on the spot or u can call them
through Skype. For more visit their website as it is very user friendly
website. Just click on the chat as the response rate will be very fast from
them and they have fixed my issues in no time.
There are 4 ways to reach them.
1. Once you open the website just click on the live chat
where one of the IJINNI technicians will be in touch with you.
2. If you have Skype installed in your machines just click
on skype icon on "ijinni.com" to make a free call.
3. You can email at [email protected]
4. You can dial at +1 512 879 3546.
For any issue you are facing with the computer just call
IJINNI
