Computers & Internet Logo
a
asanka Posted on May 12, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Asus my cinema-P7131 not sewing picture for windows 7 bit 32 machine
Carlos L. Glez
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Master 419 Answers
  • Posted on May 25, 2019
Carlos L. Glez
Master
Level 3:
Loyalty:
Answers
419
Questions
Helped
79937
Points
1953
Hello Asanka, I don't what's meaning for you like "sewing" is more acceptable ( to understand ) bookbinding.
I understand that my cinema-P7131 is used to enjoy Analogic TV on the PC, also other recording options, listen to music; to edit photos you need a photo editor, such as Movavi Photo Editor, inPlixio Photo Clip and many more!
I leave the links ... enjoy!
1) https://downloads4pc.com/movavi-photo-editor-free-full-version-download
2)
3)
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Apr 03, 2010
SOURCE: I'm looking for windows 7 64 bit drivers for the
cant emulate the environment, if you could the lag (latency) would be overwelming!
Anonymous
  • 30 Answers
  • Posted on May 12, 2010
SOURCE: driver d-lin kdu-562m for windows 7 32-bit
please try this link it might be of some help.
thank you.
http://www.bioticaindia.com/du-562m.html
Anonymous
  • 192 Answers
  • Posted on Sep 19, 2010
SOURCE: VAIO VGN-NS240E/W PC Notebook: I upgraded from Vista 32 bit to Windows 7 32 bit (...
It is required to install the following Drivers/Utilities in the following order to fix the issue with the functions Keys.
You can click on the link to download the Drivers/Utilities.
Video Driver.
Video Driver Update
Audio Driver.
Sony Shared Library
Sony Firmware Extension Parser Driver.
Sony Firmware Extension Parser Driver Update 1
Sony Firmware Extension Parser Driver Update 2
VAIO Event Service.
Please download each file in the Computer to a folder. After that open the folder where the file was downloaded and double click to begin the installation. Then, please follow the onscreen instructions to complete the intallation process. Make sure that you restart the Computer after each installation. Installing all the above Driver/Utility in the correct order should fix the issue with the Volume/Brightness Function Keys.
Good luck...!!
Mehandi Husain Suleman
  • 1654 Answers
  • Posted on Nov 03, 2010
SOURCE: i need drivers for P5VD2-X
hi
go to following link you will get your drivers
http://vip.asus.com/forum/view.aspx?id=20061223034227274&board_id=1&model=P5B+Deluxe&
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Aug 06, 2011
SOURCE: I have motherboard ASUS P4S800D-X
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question or exclamation mark? ! or a red X Right click to install drivers if you dont have a motherboard disc you will have to download the drivers http://download.cnet.com/%7Bvalue=http://www.download.com/jetway-motherboard-driver/3000-2098_4-163033.html http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
Realtek AC'97 audio driver package. The package includes: driver setup program, drivers for Vista/Windows 7 32-bit and 64-bit editions.
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html free sound drivers
http://www.boxdrivers.com
using this link you will be able select your drivers
you will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc
you might have to connect the usb lead to your modem to get a connection then
click start control panel administrive tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers if you cant find the driver hopefully one of these will help you
http://alpha.majorgeeks.com/Intel_Network_Adapter_Driver_for_Windows_7_d6273.html
http://majorgeeks.com/SiS191_Gigabit_LAN_&_SiS190_LAN_Driver_d5923.html
http://majorgeeks.com/IntelR_PROWireless_LAN_2100_Network_Connection_d4598.html Latest
http://majorgeeks.com/downloadget.php?id=5240&file=15&evp=5fbb1c6e47482358c61a5236fb38a112
VIA LAN Driver. If you don't have or cant find your land driver hope one of these will help you
Unable to instaal windows 7 on Asus A3Ac
if your computer is 5 yrs or older it might not support windows 7 also you will need a minimum of 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7
http://windows.microsoft.com/en-AU/windows7/products/system-requirements
hope this helps
1helpful
My Cinema-P7131 is not responding. I have win xp sp3.
Your P7131 may not be responding because it is not enabled. To check if is recognized and enabled check in "Device Manager" by doing the follwing. Click on "start", lower left of your screen. Find "control panel" and click on that to open. In your list, or icons, find "Device Manager". Right click on that and open, click on "continue". Ciick on box with + next to "idisplay adaptors". You will see a drop down and, should see Asus or tv tuner. Right click on that and you will see in the box, "enable" or "disable".if you see enable, click on that and you know your tv tuner is recognized and enabled.
If you need drivers you can get them here;
http://support.asus.com/download/Download.aspx?SLanguage=en-us
1 Select product-click on arrow at right of window, scroll to "multimedia" and click on to select.
2 Select series- click on arrow at right, scroll to "TV TUNER" and click on to select.
3 Select models-click on arrow at right, scroll to "My cinema 7131" and click on to select.
Click search. A window will pop up "enter your o/s". Click on the arrow on right and select Win XP or Win XP 64 bit, depeneding on what you have, and click search. This will bring up your download. Usually the top most driver is the most current. Click on your download and run.
You will notice there are three choices under select models. If P7131 is your complete model # then you have the right download.
2answers
I installed Windows 7 in the Asus M2N-MX series motherboard but could not load audio drivers. Where can I dowload audio driver from?
The drivers for Vista should work just as well for Windows 7. This is true with almost everything about Windows 7; in fact, Windows 7 is actually NT kernel 6.1! (Vista is NT kernel 6.)
1) Go here: http://support.asus.com/download/download.aspx 2) Type M2N-MX into the search box on the left. 3) Select M2N-MX from the results. 4) For your OS choose Vista 32-bit if you installed the 32-bit version of Windows 7 or Vista 64-bit if you installed the 64-bit version. 5) Have fun.
Good luck.
Install the card but to install the driver leaves a message saying the driver is not supported I have windows vista sp1
Go to the main website of your product, you have asus, i have 4650 his HD radeon went to main amd site and got all drivers up to date. but you could try the amd site for yours too.
We've just upgraded our pc from windows xp to windows 7. My install stiffies for Deco Wizard 1.0 don't seem to be working. Is there anywhere i can get Deco Wizards 1.0 on the net?
I was able to get it to install on Windows 7 32 bit, but not on 64 bit, which is sad because my 32 bit machine is pretty much dead and I will only be using my 64 bit ongoing. I tried even copying the contents of the program files onto my 64 bit machine, but can't run the application, even changing the exe compatability mode to something like Windows 2000.
I m using asus p5sd2-vm .vedio and audio drivers for win7 are nt available on asus website.can any body send me links from where a can free download my motherboard drivers. ([email protected])
Its a common problem, all you need to do is download and Install Windows XP (either 32 or 64 bit addition's) driver depending on your Windows 7. (If windows 7 is 64 bit then install 64 bit or else 82 bit for 32 bit Windows Xp usually Service pack 2).
Have a nice day !
1helpful
My graphics vidieo card of asus p4ge-mx is not supporting windows-7
The Windows 7 video driver maybe available from this WEB site :-
Driver Cure - Windows® 7 32-bit and 64-bit Operating System, Windows Vista® 32-bit and 64-bit, Windows® XP 32-bit
www.paretologic.com/lp/drivercure/lp8/index.html?gclid=CMCPwP7jjp8CFRelagodPW_eGg
AUDIO NOISE
I had the same problem. I found solution in its software. Power Cinema 5. Go in settings of TV and then go to signal settings, there enable Timeshift which is disable by default and select apply. I think this is not related to audio but by enabling it I completely get rid out of my prolem. Check it out and please inform me that what happened. My mail is [email protected]
1helpful
The TV picture is flashing
The problem seems to be due to Cyberlink PowerDirector. Most people suggests to remove it from the computer and use other capture programs. This, of course, does not explain the stuttering display of the TV channels on a Plug-and-Play LCD monitor.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
