Question about Kenmore Washing Machines
I have a commercial duty washer by Kenmore it is showing an F34 error code. We were trying to bypass the coin slot 2 wash clothes without the coin slot. And then the error code showed up since it has not worked
    Top Expert:
  • Kenmore Master
  • 30,497 Answers
Remove the plug from the wall or trip the breaker. Reconnect the coin mechanism and plug it back in. This should reset it. Put money into it and then retrieve the coins.
This article says F34 is clothes in a machine that is set to the Clean Cycle!
https://www.searspartsdirect.com/washer-repair/error-codes/kenmore-he2-front-load-washer-error-codes.html
This confirms
https://www.applianceblog.com/mainforums/threads/21037-Kenmore-HE2-F28-F22-F24-F21-F34-Error-Code
Posted on May 11, 2019
6ya staff
SOURCE:
catriver
Ron Marek
  • 878 Answers
SOURCE: Kenmore Elite Frontload washer
Dea, F02 is the code for long drain. Your filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels and unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in. See if the washer comes back to life...Catriver..post back
Posted on Apr 28, 2007
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: How to Reset a GE top load Invensys washer timer?
remove slide cover .. move the slide lever back untill it is on #1 or the lowest setting... hope it helps
Posted on Nov 17, 2008
Anonymous
  • 373 Answers
SOURCE: F20 error code no water coming into kenmore he3t washer
The following provided by fixya has the solution to error F20.
Click here for detailing on F20 Error
Good luck and please do rate my answer.
Posted on Jan 17, 2009
Anonymous
  • 3 Answers
SOURCE: maytag bravos top load washer error code F1
Well, you're not gonna like this, but here's the deal.
Remove the three screws on the rear of the control panel and lift it up. Disconnect the rubber hose on the right side of the gray control module and blow through it to make sure it is clear and not kinked. If this check is fine then your control module needs replaced.
Note that Maytag knows this is a fairly common problem. My washer failed 9 months out of warranty with this problem.
The only good news is that it is an easy, though expensive, replacement.
Posted on Sep 25, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: My kenmore HE3 front load washer will not drain or open door
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
My Kenmore HE2 plus front load washer is showing an error code and now it wont spin or unlock what is wrong with it
Your pump is blocked.prob a hair bobble coin etc... try the pump access at bottom of machine water will come out so u need to open it slowly
Jun 03, 2016 | Kenmore HE2 Plus Front Load Washer
Change the number of coins to operate
you need to take the coin slot apart take pictures as you go to put back together the parts to change amount are hidden inside it in hidden compartment if they wheren't removed by some one. your machine didn't come with the coin mech so if you don't have the parts you will need to take it with you to the parts house to get right parts. open the top of the coin mech box there are 2 long rod screws holding it in place usually 5/16 inch wrench fits may need to wiggle the heck out of it to get it out
Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Using enough water or not enough?
No affiance but dident your Ma Ma show you how to do laundry. Ask your neighbor to show you, and make a new friend.
Apr 20, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Code "rL" means???
Code rL or F34 --> Load detected in machine at the beginning of the clean cycle. Push stop, remove clothes from washer & try again. Mine did this to me, even though there was nothing in the washer. I just tried it a second time & all is good again.
Feb 18, 2009 | Kenmore HE2 Plus Front Load Washer
I just bought a house that included in the sale a Maytag Coin-op Washer and Dryer. The coin box on each contains a key. How do I disable the need for putting coins in the washer and dryer so that I can...
  1. purchase a coin insert and blank the slot that coins fit in, then the slide will slid in without coins, just acting like a button, if you examine the slide you wil notice that there are plastic inserts in unused coin slots, any maytag commercial dealer has them.
  2. replace coin slide with 'free operation' converter, which is just a button plate that pushes the striker on the timer switch
  3. take top cover off and just push the striker on the timer, (this is NOT) a recommended option, 220v is enough to spoil you whole day)
Oct 24, 2008 | Maytag Washing Machines
Kenmore 20172 Washer does nothing when coins drop
Sounds like the lever for the coin box needs an adjusment. It may not be far enough back to engage the lever to start it.
May 07, 2008 | Kenmore 20172 Top Load Washer
Fault code F20 on kenmore he2t clothes washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Dec 29, 2007 | Washing Machines
F-H code and beeping noise
error code which is serial communication error with motor contrl.
replaced M.Contl.brd but still have error.
Dec 03, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
