The blade is spinning, it's just not...blending. I just got it new
SOURCE: blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
SOURCE: Blade won't spin
Check the blade with it off the base and make sure that it spins freely. Check the spindle on the base and see if it feels hard to turn. If the spindle turns too easy , then the connection inside the base is broken and needs replacing.
Testimonial: "Great feedback! thanks! "
SOURCE: A spoon was in blender for a few seco nds and does
having the same problem, called vitamix and for $15 CDN they'll send me a new Drive Socket. Apparently they're setup to shear if something like a spoon gets in there. Prevents the motor from being destroyed.
SOURCE: Waring Pro Blender is leaking and blade assembly is loose
I know this is an old, old post, but I could not find a solution anywhere, so hopefully this will help someone. We have a model 51BL25, similar to scottman55's blender, and it had the same problem. There are two separate nuts in the blade assembly. One holds the blade on, and the other holds the seal tight. When the latter gets loose, the blender shakes and leaks.
To fix it, first you have to remove the top nut holding the blade on. I had to get in there with pliers, but a ratchet with an extension would be perfect. This nut is right-handed ("normal"). Once that nut is loose, you can remove the nut and the blade. You will also want to remove the washer immediately under the blade (take note of which side goes up).
Now, you can pull the whole axle out by the wheel on bottom of the blender. This exposes a really thin, flat nut. In my case, this nut had come completely off, so nothing was really holding the seal together at all. Again, make sure you remember which direction the nut goes -- it is not quite symmetrical. That nut is what comes loose when the blender starts leaking. By the way, it is a left-handed nut, so it screws on counter-clockwise ("backwards"). Screw it in tight, then put the rest of the blade assembly back together, and your done. If you have the right tools, it should take only maybe 5 minutes.
Depending on your problem/model, this may or may not solve your problem. Hope it helps!
