It's a replaceble part correct? Check ebay. or [email protected] ' (626)-656-5982
SOURCE: how do i remove the chuck on a hilti dd100 core
go to Hilti.com and type in your model number for an owners manual on this tool. It looks like it has a locking mechanism that you just need to pull back. Let me know if you can't find it and I will get more specific info, or you can call them at 1-800-879-8000 and speak with tech services for this
SOURCE: How to install trunk lid trim on 1968 mustang?
the two nuts go at the end of the trim two bolts sticking out of the trim drill two holes at the ends of trunk which should all ready be there. the middle clips go along the middle the trim snaps on to them
Bruce Pike
Testimonial: "Ok, 2 bolts at each end. and drill all other holes equally spaced for the middles clips? I wish there was a pic or template that I could see?"
SOURCE: HAVING A PROBLEM WITH MY HILTI TE5 HAMMER
the bearing in the chuck is probly missing. replace the ball baering.
SOURCE: hilti te92 starts up then stops after a little use
It could be the contacts on the switch are burning out. The 92 also had an electronic speed regulator that could be going out.
After you run the drill and it stops. Unplug the drill, take the handle off and apart. Feel the screws on the switch were the wires are connected. If one of them is hot to the touch that usually means the contacts are burning up.
SOURCE: te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
