Hi Seth.
If after pulling the timer knob the washer will not start, you can test it for continuity with a multimeter. Remove power from thewashing machine and find the timer contacts. Some toploaders have a start switch that is a momentary contact type of switch. This switch will be located on the control panel.10 Apr 2015
Washing Machine Will Not Start - What To Check - How To Fix
or try this link.
https://www.google.com/search?q=Top+load+washer+whirlpool+is+not+running&rlz=1C1AVFC_enGB797GB798&oq=Top+load+washer+whirlpool+is+not+running&aqs=chrome..69i57.4230j0j9&sourceid=chrome&ie=UTF-8
SOURCE: My whirlpool top load washer will not start when I pull the knob. It makes a humming noise.
Motor sounds like its not starting up strong
May need a motor....
SOURCE: top loading whirlpool model lsq9549pw2 will not spin
This is commonly caused by a broken motor coupling. If the washer fills and drains, but will not agitate or spin, the motor coupling is likely the cause. The coupling takes the place of a drive belt and couples the drive motor to the gearcase (transmission). This configuration is known as "direct-drive". The coupling can wear out due to normal wear and tear and easy to replace. The following link explains how:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
This is a very inexpensive repair and its not difficult if you follow the steps provided. The newer replacement couplers are more resilient and resist breaking much better. The part number is included in the link I provided. You can purchase a replacement at appliancepartspros.com for about $11. If you do not wish to order on line, take the part number and go to your nearest appliance parts retailer. This is a very common part that they should carry in their in-store inventory.
If you have any questions about this repair, or if you need additional assistance, plese let me know. I hope you fin dthis information helpful.
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
SOURCE: Whirlpool top loading washer, spin cycle just quit.
From the symptoms you describe, it sounds like you may have a broken motor coupling. The coupler is located between the drive motor and gearcase (transmission). It takes the place of a drive belt. This configuration is known a "direct-drive". The following link explains how to replace one:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
Replacement couplers are improved and more resilient to resist breakage. The part number is included in the link I provided. You can purchase one at appliancepartspros.com for about $11.
If you have any questions about this repair, please let me know. I hope this helps you.
SOURCE: Whirlpool Cabrio WTW6600SBT Top Load
f1 is the error code for your main control board at console, replace boad
