Probably you should look for problem with your IP adress. Maybe change it? VeePN is good opportunity to connect to wifi through another ip-adress. I suppose it can solve your issue
Turn on the Wi-Fi and connect to a network. Long press on the connected network and select Modify Network. On IP Settings drop down menu, select Static. Assign IP of your choice but leave other variable untouched.
How to Fix Failed to Obtaining IP Address Error in Android
Method 6: Assigning a static IP address
More items...
13 Sep 2018
Fix: Failed to Obtain IP Address - Appuals.com
To give your computer a fixed (static) IP address:
More items...
Create a connection with a fixed IP address
When a malfunction arises the device fails to obtain an IP-address within the available network. Your device disconnects the network automatically, then tries to connect once more to obtain an IP-address again. The attempts don't stop. There are several reasons which cause the "Obtain IP Address" error.14 Oct 2017
How to fix when Wi-Fi is stuck "Obtaining IP Address"?
IP Configuration Failure: Your router may be failing to assign a proper IP address. Usually, this issue can be solved by simply restarting the router. You might be in a poor network coverage area: Shift your device to the area where the network signal is good.
SOURCE: Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
SOURCE: netopia 2247NWG for smarttelecom
Sorry if my writing is not clear I dont have best english.
If you move your router from eircom to smartelecom you have to change security protocol from "chap" eircom to "pap" smarttelecom.
Now Do this few steps.
Go to start menu on windows find and click run.
type: cmd and press ok
When you will see black screen that will be command prompt.
Now you have to type your defaul ip adress. To check your defaul ip adress type ipconfig in command prompt and press enter.
Default Gateway is your default ip adress. Now when you know your ip type in command prompt:
telnet yourip 23 and press enter, for example:
telnet 192.168.1.254 23
If you didnt setup any password to login to the router you will be loged automaticly and you will see "Netopia-2000/18861188>
But if you have setuped login and password to your router you have to first type your login and press enter,then password and press enter to have acces.
next is easy type:
configure and press enter
ppp and press enter
set and press enter
now you have to pressing enter about till you will see line:
option <chap-only> [ off : on : pap-only : chap-only ]:
on this line type pap-only and press enter
now start pressing enter till you see:
Netopia-2000/18861188 <ppp>>>
then type save and press enter.
When you see line:
Configuration data saved you can close command prompt window.
From this moment your router will be work with smarttelecom.
SOURCE: will not connect to my
i cant connect to the wifi i have a rooter on my android acend it connect to my labtop but my cruz reader wont even make the wifi pop up its not found
SOURCE: motorola mc55 wifi problem
Hi Chris,
Pls check in wireless settings>> security settings.
Whether any MAC authentication is enable with the AP (Access Point).
If yes, kindly add the MAC address of your device which you want to connect to the AP.
SOURCE: Motorola MC3190 can not get ip address from dhcp on wep wi-fi
To configure the terminal TSD on Windows Windows do the following:
1. at the bottom of the panel find the network icon (it can be crossed with a red cross or be a red exclamation mark)
2. click on it with the stylus and select Options Options
3. In the window, select the menu and set the following values:
OP Mode Filtering - leaving only a tick AP Networks, and remove Ad-Hoc Networks
Regulatory - select the country (you can USA) and remove the checkbox Enable 802.11d
Band Selection - I chose only 2.4 GHz Band, 5 GHz mark removed
System Options - all ticks left (Profile Roaming, Enable IPv4 Mgmt and Auto Time Config)
Auto PAC Settings - AllowProvision ing AllowRefreshin g and both set as No
IPv6 - Enable IPv6 checkbox removed
Change Password - leave blank
Export - click the button Export Options, a window to save, note that saving should be in the folder \ Application and contain letters and symbols with the extension. Reg
After that, push the Save button and
i had got this try may be this help you :
It is a problem due to DNS server ip address.If you configured ip address in mobile manually to connect wifi check the DNS address.If you have connected to wifi automatically means there is a problem of DNS ip in the wifi router configuration.Google has public dns of 8.8.8.8 if possible configure in Mobile and try it
By senthilkumar R Oct 28, 2010
