Https://www.brita.com/wp-content/uploads/19329000.023_BRT_CBI_FF-100_UsersGuide_R9_i01_Complete.pdf
Support the bottom of the filter system with one hand. Align the insert groove on the lower part of the cartridge with the Filter Replacement Indicator at the front of the filter cup. Insert the filter cartridge into the filter cup until a "click" is heard. Do not force the filter cartridge into the system base. Inserting the new filter cartridge automatically resets and activates the electronic Filter Replacement Indicator. A green signal will flash, indicating that the filter is engaged.
SOURCE: DELTA MODEL 470-WH LOW WATER FLOW AT KITCHEN FAUCET
This could be a couple of things.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
SOURCE: indicator light for Brita filter not working
I see this alot when I do installs...contact the Brita tech support
1-800-24-BRITA (US)
SOURCE: Keurig states Ready to Brew, but it just spits
This same thing happened to me yesterday. I would start to brew, a teaspoon of water would come out, then nothing. I didn't descale because the pump wasn't pulling water. After calling Keurig, I decided to mess around with my machine since a new one was on the way. Check the intake valve where the reservior hooks up. I noticed some standing water in mine, so I spent 30 minutes siphoning it out with a twisted paper towel. I didn't think it would work- but it did! Back to full functioning, at least for now. Keep siphoning until the towel end comes out completely dry.
SOURCE: Brita faucet filter will not stay on faucet
Want a free adapter and patient enough to wait for a couple of weeks to get them?
"To receive a special adapter free of charge, call 1-800-24-BRITA or 1-800-387-6940 (CANADA)."
Call the number above and a voice prompt will give you instructions on how to get your adapter for free. 2 weeks might be too long but the best thing is it is made of stainless steel/chrome and it comes in 3 different kind of adapters with rubber washers.
SOURCE: low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
