SOURCE: Washing machine Kenmore 3.2 cu ft Super capacity plus top loader
fabi, if Im reading you right the machine fills with water and just sits there. Can you hear the motor running when it should be agitating? If so you might have a broken coupler. If the machine is quiet and just sits there, it could be the pressure switch. The first picture shows the pressure switch with the rubber hose and purple wire going to it (far left). There is no model number posted but this is a top loading Kenmore, should be close. Take the rubber tubing off the switch and blow into the switch with another piece of tubing. Does it start agitating? If so, there's your problem. If you do hear the motor running and it's not agitating it may be the motor coupler. If you need more assist...email me at [email protected] Catriver..post back.
SOURCE: Kenmore Front Loader-Doesnt Aggitate nor Spin
the speed control board needs to be replaced in the lower rirght corner of the washer
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
