Question about Kenmore Refrigerators
I have a Kenmore Elite freezer model 253.28712809 and the door ajar alarm keeps going off when the door is closed.
Kenmore freezer model 253.28712809 door ajar alarm keeps beeping and the door is fully closed with all seals intact. I checked the door switch and it is working intermittently with the alarm sounding even when the door switch does work. Would replacing the door switch fix my issue or could it still be the control panel?
Anonymous
SOURCE:
nealsnewmans
SOURCE: Kenmore Elite bottom freezer refrigerator model 795.77573600
My Kenmore Elite (Model 795.7755 3600), less than two years old, had the same problem. One morning I opened the doors to a hot fridge and burning plastic. The light housing was sizzling hot - much of the unit literally melting away. Another hour or two and it could have been much worse.
Called the 1-800 number listed in the fridge. After about 45 minutes of patient talking, I learned that Sears (or Kenmore) have issued what they refer to as a "flash warranty) on the light fixture kit (Kit # 6871JB1423N) which in effect, for this part only, extends the factory warranty from one year to three years. I may even be able to have a factory tech install the parts. Hope it works out.
Bottom line: if you have this fridge, be very careful and monitor closely. An pursue the part warranty!
Posted on Jan 13, 2009
Anonymous
  • 121 Answers
SOURCE: freezer alarm
nana,
Your defrost elements are not working or the inlet to the evaporator tray is clogged, if you haven't gotten iny icy water build-up in the bottom of the fridge you will soon. This may require a service call.
randy320sgi
Posted on Feb 11, 2009
Anonymous
SOURCE: kitchen aid open door sensor alarm keeps going off door is closed
Open door and turn power off then on twice. Then press the Overtemp reset.
Posted on Aug 08, 2009
Anonymous
SOURCE: Samsung RB1855SW won't stop beeping and fridge malfunctioning
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
Posted on Feb 12, 2010
allen_haney
  • 266 Answers
SOURCE: The "door ajar" alarm keeps going off and the door
Your door switch may be bad. Is the light on when you open the door when you manually push in on the switch does the light go off? On most fzr the door ajar alarm is set off by the door switch showing the door is open.Turn off the power by unplugging the fzr then you can pop the switch out with a flat blade screw driver if it is only a two wire you can use a paper clip to connect the two wires wrap them with elect tape Then plug the freezer back in and see if the problem clears if it does order a door switch. Some units use a vacume sensor but i believe all kenmores use the door switch. good luck
Posted on Aug 17, 2010
Freezer bleeps as if door open. Temp goes down on its own
Kenmore freezer door alarm beeps but door is closed ...
www.shopyourway.com > Manage My Life > Questions
Every once in a while, the door ajar light goes on and the alarm beeps and will not ... Ifthe door is closed good and the door alarm is sounding, it will indicate the ...
How to fix constant refrigerator door alarm beeping? - Shop ...
The doors aren't open and we have checked the air flow vents and made sure ... We have to turn the alarm off to get it to stop beeping but I more concerned about ... If the fresh food section lights are working, meaning you can get the lights to go ... Thefreezer fan motor would need to be checked to make sure there motor is ...
Jan 12, 2016 | Refrigerators
Why is door ajar alarm on when door is closed
Hello friend, thank you for your post!
I see that your door ajar alarm is going off when the door is closed to your Frigidaire freezer. It sounds like a possible issue with the control panel or switch. Let's perform a reset to your appliance to see if that will correct the issue. You can do that by disconnecting power from the appliance for roughly ten minutes. I hope this helps. -Matt
Sep 22, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer light doesn't work and door ajar alarm going off
The door switch is faulty. It switches the light on. There is no battery.
Dec 27, 2012 | Kenmore Freezers
The "door ajar" alarm keeps going off and the door is sealed shut?
Aug 17, 2010 | Kenmore Freezers
The temp alarm keeps beeping, although the temperature seems fine
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 04, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
Alarm no longer sounds when fridge door is open
Chances are that you will have to replace the buzzer. That part is available at Sears Direct. J
May 28, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Feb 05, 2010 | Freezers
Kenmore elite refrigerator alarm keeps going off even though the doors are closed
you have to send model number,on some bottom mounts there is a metal striker on the door that hits the switches,sometime that gets bent back,all you have to do is readjust the striker by bending it if screws aren't loose but i don't know what kind of bottom mount you have
Nov 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer Alarm keeps going off...
I think your freezer's coils have been damaged. Consult a enjinner.
Aug 10, 2009 | Kenmore Freezers
Refrigerators Logo
142 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
