I have weighed the weights, and have tried a small hand held force gage to check the forcing pressure, and have had varying readings between the processes. How am I able to verify these weights? Any help would be appreciated. Thanks. Rich
SOURCE: My Scale stoped weighing me, now it reads 1-ld .
The sensor has been worn out or has been pushed past it's weight limit. When you get on it, it pushed the sensor past the point of working... When she gets on it, no problemo...
SOURCE: 97 cadillac deville power window motor replacement drivers side
The motor sit on a gear stem you will have to wiggle it a little to get it off the magnet inside is holding it to the window frame just use a little pressure to remove.
SOURCE: the stylus skips across the record, despite
If your needle skips across the record, then there is only 1 thing wrong with it... it's broken, and needs to be replaced.
If after you've replaced the stylus, and problem persists, then you have something a little more serious... Tonearm damage. More than likely not, but just in case replace the stylus does not help.
- OPTiC
Master Tech
Digital Analog Therapy
Technics Repair : Technics Turntable Parts
SOURCE: Need a port for my MS force feedback pro
Just get yourself a new soundcard with a gameport on board. Disable your MoBO soundcard if you have one and instal the new one. Creative is probably the safest option. Update the drivers and off you go. Don't forget to add the joystick, the drivers are supplied in XP.
SOURCE: i get a force close message on my phone. what do i
This basically means the OS is having severe problems. You need to try a master reset first. If this does not work and there is no software update available from the HTC website you need a replacement handset.
