Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Does the Sabre gx1438 have an oil filter - Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
    Top Expert:
  • Craftsman Master
  • 66,253 Answers
2 Suggested Answers
6ya staff
SOURCE:
Manual for Sabre Riding Mower Model GX1438
Try Googling (sabre)(GX1438)(manual) without parens.
Jun 23, 2017 | Garden
2006 Honda Shadow Sabre 1100 oil pressure issues
Hi, Anonymous you may have a faulty sending unit to check for normal engine oil pressure, make sure the engine oil level is between the add and full marks on the dipstick. Remove the oil pressure sending unit, located on the right engine case, behind the oil filter mounting bracket, and replace/plum/or rig with a known good mechanical gauge that reads 0 to 40/50 lbs. Start the engine and run it until the engine oil reaches the normal operating temperature of 230 degrees. At 1,000 RPM, the oil pressure should be 2 to 4 lbs. at 2,000 RPM the oil pressure should be 30 to 38 lbs. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Oil Light Problem 1998
1996 Honda Shadow ACE 1100 Oil is full but oil indicator came on Fixxit
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda Shadow VT1100 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 12, 2017 | 2005 Honda VT 1100 C2 Shadow Sabre
Sabre 17.542hs loss of power
you could have a weak coil and misfiring under a load each cylinder has it own coil on that engine you can get a inline spark tester to see
Sep 03, 2012 | John Deere Garden
1996 Honda VT 1100 C2 Shadow Sabre oil in the air filter box
Hi, Wayne and the usual suspects are:
1. Oil tank/system overfilled.
2. Faulty breather valve.
3. Engine breather hose bent, pinched, kinked etc.
4. Air filter has too much "pre-oil".
5. Crankshaft seal failure allowing transmission fluid to migrate.
6. Blow by drain tube cracked/split or filled to capacity.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Oil in the air box
Honda Shadow Spirit air filter sub air cleaner crankcase breather
Honda VT1100C2 Owner Manual Page 3
May 29, 2012 | 1996 Honda VT 1100 C2 Shadow Sabre
I have a 2004 Honda shadow sabre, what oil weight is recommended in wisconsin?
Your motorcycle comes from Honda usually with 10w-40 mineral base motorcycle oil. This is what they recommend for year round driving. You can use any oil that is JASO MA certified motorcycle oil. 10w-40 for cold climate (Wisconsin). 20w-50 for warm climate/touring. Car oils use different additives and may cause scoring in certain types of cam bearings. Do not use any oil that says " Energy Conserving " on the label . It will shorten the life of your wet clutch and transmission gears. If you choose Synthetic oils, they will help your bike run cooler and shift easier. Shell Rotella T and Rotella T Synthetic 15w-40 are inexpensive JASO MA oils. The 15w-40 would be a great all around weight for your needs. You will need 4 quarts of oil, an aluminum drain plug washer, and a filter. Pour in 3.2 quarts , run the motor, and check the oil level . Top up as needed.
Mar 13, 2011 | 2004 Honda VT 1100 C2 Shadow Sabre
I have a 2002 Honda VT 1100 C2 Sabre and I just flushed all of the oil out of the pan and also changed out the filter. How many liters of motor oil do I have to put back into the reservois?
I have checked my service manual and it does not state quantities just top up the oil until the glass level is up to the mark. Don't forget the oil filter will take a little extra oil.
Sorry
Feb 01, 2011 | 2002 Honda VT 1100 C2 Shadow Sabre
15.5/42 manual & oil filter
may not have a filter.try briggsand sratton.com. you will need all the info off the data plate on the engine
Sep 13, 2009 | Garden
What is the correct oil capacity for this motorcycle? 1100cc
Use 20w40 SF or SG motor oil in the gear box, 20w50 in hot states like Texas. Don't use any synthetic oils, oil marked "EC", or oil with "special" additives. Stick with the major brands; Pennzoil, Quaker State, Mobil or Shell. Without filter change it takes 3.1 quarts. With filter change it takes 3.3 quarts.
Please take a moment and rate this answer. Thanks!
Jun 24, 2009 | 2001 Honda VT 1100 C2 Shadow Sabre
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
48 people viewed this question
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
