SOURCE: Roper RS22AQXMQ00
When you try to get ice does it make any sounds (clanks, whirring, grinding,etc.) like something is happening inside or is it just quiet? If quiet, see if you can look up inside the door switch area with a flashlight and press the button with your finger instead of the lip of a glass. Post more info when you have it and we'll go from there.
SOURCE: How do i remove the ice dispenser panel form the
Kneel down and look up from the bottom, you will see 2 small slots on the bottom of the dispenser panel, insert a putty knife or screwdriver in the slots one at a time and push up hard and twist slightly. If you gently pull on the bottom front of the dispenser while doing this it will help release. Once this is loose you can disconnect the wires. Be sure the frig is unplugged!
