When I wind it up, it feels like there is something lose between the winding stem and the cogs. Do you think it needs oiling?
SOURCE: Pulsar Men's analog wrist watch - how to set day and date
Pull crown out to 1st position....Turning one way will alter the date and turning the other way will alter the day.
SOURCE: keeping 2008 breitling cockpit watch running
You have to wind the watch till it is fully wound (significant resistance should be felt).
It doesn't matter how many times you wind it (1 or even 40) - what matters is the strength of the spring.
Do as follows:
At any time in the morning wind the watch up till you feel there is no more winding left (should be quite tough). Memorize the time you did it.
Leave the watch (or wear it) till it stops completely.
Count the hours your watch did work (from the time you wound it).
Now you know exact power reserve for your watch.
It is advised to wind the watch 2-3 hours before the power reserve is gone.
Rate me.
, please.
SOURCE: My watch no longer functions even after winding.
I have found that some of these "automatic" Fossils also contain a battery. That is how that provide an automatic watch at such a cheap price. I recommend taking it to a jeweler to have them check this. If it needs repair it will likely cost near the watche's replacement value.
Testimonial: "Thanks Admiral Adam, you provided some valuable insight into my problem"
SOURCE: How do I wind my Tissot visodate seastar automatic
Are you sure it winds? They also make battery operated watches! :-)
SOURCE: Elgin 18s pocket watch (1908). Will not wind,
Sounds like a broken main spring.
This is a fairly easy fix and may also be due for a cleaning and service.
Find a local repairman in your area.
http://www.nawcc.org/business-directory/
Hope this tip helps
R/
David
Please dont forget to vote this answer was helpful.
Many thanks
