SOURCE: bushnell 400 rangefinder won't show yardage
does anyone have the same problem? How do you fix it?
SOURCE: Need Instruction Manual for Leupold RX-IV Rangefinder
I was able to print out the instruction manual. Thank you.
SOURCE: bushnell 400 rangefinder won't show yardage stuck on 888
If the unit is stuck on 1888 the circuit board inside has lost its programming. Sounds like its about 10+ years old. Bushnell doesn't work on them anymore. If you use it for hunting I would suggest the Scout 1000 with ARC compensation, if you use it for golf look at the Medalist. You can see them both at bushnell.com
The hunting rangefinder will run about 250 bucks
The golf rangefinder will run about 220 bucks.
Both use advanced target locking systems.
mtg
SOURCE: I have a bushnell 1500 which has stoppeed reading yardages
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
SOURCE: I need a user manual for a Leupold RX-II
Go to the leupold website. look under resources. you can download the pdf manual
