SOURCE: Craftsman lawn tractor mower,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
SOURCE: hydrostatic drive
Try using the heel of your shoe and pulling back on the brake/clutch pedal and see if it helps. Cronic problem with these mowers-Belt slipping when linkage get a little wear-with no solution???
SOURCE: craftsman riding mower-what year was it made
Hello! The 917= American Yard Products...A major supplier to Sears...The first six digits of the SN#...00/00/00= date of manufacture...In your case...May,1,1997...
Guru.....................Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Testimonial: "Thank you very much!"
SOURCE: How do you replace drive belt on a hydrostatic
Its not a hard job just push in clutch and lock it, remove mower belt then replace drive belt and then put mower belt back on and release clutch.
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Thank you for the advice I will check the belt and see if I can find where to check the fluid
