Check to see if the drive belt has snapped or come off the pulleys?
https://www.google.com/search?q=craftsman+gt3000+drive+belt
SOURCE: craftsman gt 3000 will not drive.
Hi there, On the Craftsman 3000 there is a pin on the back end of the mower that when pulled outward disengages the transmission so it can be moved without it running. Sometimes this pin will stick. It is connected to a lever on the transmission try to push and pull the pin in and out a few times to see if it will free and engage again. You might have to reach under where the lever is connected to the pin rod and try to move it back into position that way. DO NOT REACH IN TO THE TRANSMISSION AREA WITH THE MOWER RUNNING!!! But the pin must be pushed inward for ingagement. This pin will let the mower just sit there like its in nutral and not go anywhere. Try it!!
SOURCE: Engine dies when I engage the electric clutch for my mower
Possible short to ground in the clutch wiring
SOURCE: I have a craftsman LT 3000. It started fine and
you mght check to see if the belt has jumped off
