SOURCE: Appropriate size inverter for sump pumps
First...you need to find the amperage on the pump...your inverter is rated for 6.25 Amps...(750/120)...you will need an inverter bigger then the pump..I would suggest at least 1.5 times the size of the pump..bear in mind,..the inverter wasnt designed to start motors...so oversizing is needed..
Hope this helps
SOURCE: My sump pump fails to work during big rains. If I
if you dont know how old it is and think it is really old replace floods are never fun
SOURCE: MY DISCHARGE WATER FROM MY SUMP PUMP SMELLS LIKE
It's very old, stagnate water full of bacteria. Poor some Clorox in the sump and let it sit a while. Not the whole bottle, a few cups.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
you can remove and replace the oil pump with the help of repair manual easily also any other problem if you face can be resolved through manual so go to the given link and get the manual http://toolsnyou.com/ this is a safe and very helpful link
