Garden Logo
Posted on Aug 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My cub cadet ztr 50 keeps breaking drive belts the 1st after 130 hours and now after 4 hours
Dennis Sharp
Level 2:
  • Expert 154 Answers
  • Posted on Aug 07, 2009
Dennis Sharp
Expert
Level 2:
Answers
154
Questions
0
Helped
57367
Points
246
There can be a rough edge on the drive pulleys that cause the belt to get cut
Why does the deck drive belt on a cub cadet 2042 keep coming off and or breaking every time you try mowing the yard ?
My first guess is the belt is not properly routed through all the pulleys and past the belt keepers. Please check everything twice against the belt diagram in your operator's manual.
2answers
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Why is my Cub ZTR 50 keep braking belts? I only got 30 minute out of the last one at $40.00 a pop I can't keep going on.
check all the blade spindles for seized bearings. also check the pulley alignment, those issues can cause premature belt failure. Also proper tension can give you consistent long term use.
Dec 03, 2012 • Garden
3answers
Cub cadet belt keeps coming off the deck
Link to see video of the Fix for cubcadet deck belt coming off can be viewed here: http://www.youtube.com/watch?v=Pd4nYovcnvY
Hi i have a cub cadet 2518 and my pto belt keeps breaking (2) belts today 4-15-10 and only one in years past ??? what could be the problem ??? ty don
siezed pully bering check to see if there is a grease fitting if not get PB BLASTER best stuf ever made to loosen up tough stuf
3answers
Cub Cadet mowing drive belt often breaks or jumps the pulley
sounds like possibly burrs on pully, or pully depth is incorrect, causing belt to jump.
Cub Cadet ZTR M60, left transmission slipping.
mostly all lawn equipment gear axles & engines run on sae 30 weight oil & it should be 1/2 to 3/4 full unless told other wise
Jun 05, 2009 • Garden
51helpful
5answers
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
5helpful
3answers
How do you replace the mower belt on a cub cadet?
check the alignment of the ideler pully to make sure it is even withe the drive pulleys. if not in line it will cause the belt to break. There is a spacer that is on the idler that should be on top and not on the bottom of the pully.
Top Garden Experts
Jay Finke
Jay Finke
john h
