Garden Logo
Jerry Scarborough Posted on Apr 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where does anti sway bar attract on 54 in craftsman riding lawn mower
CJ Rock
Level 3:
  • Craftsman Master 4,417 Answers
  • Posted on Apr 20, 2019
CJ Rock
Craftsman Master
Level 3:
Answers
4417
Questions
0
Helped
1640881
Points
14985
5 Related Answers
Anonymous
  • 2559 Answers
  • Posted on May 15, 2009
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
wadembly
Wade Mobley
  • 513 Answers
  • Posted on Jun 28, 2009
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Anonymous
  • 2702 Answers
  • Posted on Nov 16, 2009
SOURCE: craftsman riding lawn mower tries to start and
it sounds like its the exhaust is blocked up or/and air filter, its the back fire that makes me think its a blocked exhaust,, iv had it before!
try taking it off and starting it up,,,,and yes its going to be noisy if it go's! untill you clean out the pipe, then put it back on again,
Anonymous
  • Posted on May 08, 2010
SOURCE: possible carburetor problem? Mower runs for
i have a lt 1000 2005 when i start it with cold engine it boggs for a minute then it starts to run smoothly please help me
Anonymous
  • 19 Answers
  • Posted on Jul 19, 2010
SOURCE: lost key to craftsman lt 1000, where can I get raplacement
sears has them on a hook where the filters are located.
1helpful
I have a Craftsman, 26 hp, 54 lawn Tractor that will run for a while and hen shut down after it cools for a while it will start back up.
Do not use gasoline with ethanol! Ethanol is attracting humidity which turns into water during storage.
How do you Assemble the anti-sway rod on a Husqvarna mowing deck?
The anti-sway bar fits into the frame. Then the sway bar then fits into the deck and connects with a washer and clip.
Front axle stablizer
Every manufacturer calls them different names. i worked on trucks all my life and I would say stabilizer links or anti sway link. It is a Sears mower the model number should be under the hood kinda hidden on the side of the body. Google for a .pdf parts for that model.
How do I acquire a belt diagram for a craftsman 54'' mower deck?
Search for your model number on sears site. If 0 results, search google with your model number. Owners manual usually has diagram.
I need the sway bar bracket number for mower 917-272263
The parts lists for the Crafstman 917.272263 mower is available here: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917272263/0247/1509200?shdMod=917.272263&sid=C2CxSPDxModelSearchxModelNotoSPD . The Sway Bar Bracket is on the Mower Deck diagram (part 3) is part number: 138017 . Sears Parts Direct lists this part as backordered. However, a vendor at Amazon does appear to have it in stock. See http://www.amazon.com/Husqvarna-138017-Bracket-Assembly-Craftsman/dp/B0057ILJAA ; this bracket fits several mowers, including Sears/Craftsman mowers.
I hope this helps.
Apr 21, 2012 • Garden
My deck is not level after removing it for blade sharpening. It was cutting level. Where does the anti sway bar connect? biazzio@yahoo,com
you need to go to the sears parts website, or the craftsman website, and get yourself an owners manual. these generally can be downloaded for free. in the manual there will be directions for leveling
the deck. a google search may take you to a fee site, so go to the sears sites first. the thing was made by AYP so you can google that too in case sears and craftsman do not have free downloads.
I need a operating maual for a craftsman riding mower 28990
Sears Manage My Life has the Operator's Manual: . Click on "Craftsman Lawn, Tractor" to get to the manual page.
13helpful
4answers
I have a Husqvarna YTH 2348 the deck anti sway bar came looses fell of frame and bent, I removed rod strightened and need to kown how to put rod back in proper location on the frame and deck bracket
Once you've straightened it - you've finished the hard part. Now take the end without the pin and stick it into the hole located on the transmission frame (the metal piece that the transmission sits on.) It is directly under the seat. The hole is on the front side of the tranny frame. Once you have it all the way in, take the pin end and put it through the mower deck brace (right side.) There is a hole there also for this end. If it doesn't go through enough to get the washer and pin through, push the mower deck towards the anti-sway bar. It should give a lot since the anti-sway bar is off. Once you fasten it, your'e done!
I only know this because it just happened to me today. I have the same mower as you, so I thought I would share.
Brocken sway bar bracket for craftsman riding lawn tractor/48"cut
see if you can find a diagram of your model online there should be something
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
