Already deleted cache(s) and also got rid of all posible/delete(able) apps , but still got intern memory 704 mb and amout off app's >> a totall of 0.93 gb
SOURCE: LG KG 195
hey man ! first of all there is a problem with this phone that it stores applications in the limited memory provided to it that cannot be increased . so go to the games and applications options and choose settings then open memory status and check the amount of available space .
if the application you are installing is greater than that size than naturally it wont install.
if the application you are installing has valid space then delete anything which you have alredy added in the applications and restart the phone the amount of space will increase.
this solves the problem for me hope it does for you too .
ps
if you have already got the solution then plzz ignore this
SOURCE: Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
Carla
SOURCE: SD card(s) - not enough free space?
Formatting the SD card to FAT32 instead of FAT16. Also, when the card is in the reader & you're looking at it on the Mac, empty the Trash while the card is still plugged-in.
SOURCE: My HTC P4350 is running low on free storage space
The system have used nearly the maximum internal memory available: Storage: Total 33.45 MB; In Use: 32.80 MB; Free: 0.66 MB Program.
If you already deleted or moved to memory card your files, that means that the space is taken by installed application/games, or by files left over by previously installed applications.
Save all your files on computer and do a complete reset of the HTC, restoring system to factory settings.
SOURCE: how i remove write protection in my mini sd memory card
Just go in these page there are a solution...
http://www.instructables.com/id/S27LXZRF7DWO18T/
