SOURCE: Initialization failed - Unable to acquire TWAIN-compliant device
Hello, I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop. Well, Printer Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook. You may receive some communication error messages if you are using a "PORT REPLICATOR CABLE"( USB TO PARALLEL connector). The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use mentioned by Panasonic Manufacturer. Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality. Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops. I hope that this will resolve the issue for you. You can email me at [email protected] if you need further assistance. Bye.
SOURCE: Scanner problem of Epson stylus CX5500
There is 4 buttons on the left hand side of the unit, these are for copying only. the scanning component of you printer is software driven. You will need to have setup the Epson scanning utilities on your computer. These came with the printer when you purchased it, however are also available for download from Epson in your country / region. Just go to www.epson.com and select your country and download the scanning utilities for your printer.
Gremlin11
SOURCE: C4480 cannot scan to pc
I can not scan from my printer to my pc. I have a hp c4480. everything works on it. bill
SOURCE: Cannot scan anything on my lexmark 4550
There is a patch that you can download and run to resolve this issue.
Step 1:
Download the following patch: http://swdownloads.lexmark.com/Patches/3500-4500/3500-4500.exe
If the problem still exists, follow Step 2 below.
Step 2:
Download the following patch: http://swdownloads.lexmark.com/Patches/3500-4500/3500-4500wifiethernetpatch.exe
If the problem is still the same
1.Get the printer ip address of the printer (ex: 192.168.1.10)
-press settings on the printer panel.. go to network setup.. View TCP / IP, open a browser (IE or mozilla) and type in the printer ip address
-you will see the printer page and then go to configuration.. choose scan to network host
-delete all the computer name listed
2. Go to start, all program.. choose Lexmark 3500-4500 series and choose Lexmark Solution Center
-go to Advanced, click on networking and then click on Change PC name or PIN
--rename the PC name and then click on Ok
3. Turn off the printer, unplug it for 10 secs
4. Try to scan, it should work
if it's still the same you need to uninstall the printer driver and download the updated driver in Lexmark.com
-reinstall it using the downloaded driver
GOODLUCK!!!
SOURCE: Perfection 2400 scanner fails to scan; just clicks
The only thing that usually causes a scanner error of this type is either a scanner failure or the transport lock. Locate the lock and make sure it is in the unlocked position. Lock and unlock a few times leaving it in the unlocked position then power the scanner off and on again.
Bye.
