SOURCE: Iron No Longer Heats Up
Recommended solution, gently shake, did not work.
Considering the iron was at a minimum two years old, I decided to purchase another Rowenta. I found the recommended solution documented on a FAQ sheet enclosed with the new iron.
I actually own another Rowenta iron (I now have three) that has the same issue. I will send one iron, the one manufactured in Germany, to a Rowenta Service Center to see if can be repaired - it was the first Rowenta iron I purchased and it provided several good years of service.
SOURCE: trouble cleaning Sunbeam iron 3983
you can buy an iron cleaner from your hardware store, wallmart sell it.
SOURCE: is posible to clean iron sole plate by steel
use the green no scratch pads,they are not so abrasive.
SOURCE: sticky black mark under my tefal iron
yes i did fix the probleme thank you. I did not that if i use you it would cost money.
SOURCE: the sole plate of my steam generated iron is clg
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Self-Cleaning and Maintaining Sole
Plate Use the self-cleaning feature once a month by
moving the steam lever back and forth from the "dry" setting several
times. This will remove any residue from the steam valve and ensure that the
steam system works properly. Wipe the sole plate with
a soft, damp cloth while the iron is cool and unplugged. Run the iron over a
cotton cloth several times to remove any residue from the sole plate. Cleaning Anti-Calcium Feature Fill the water cup that
came with your iron. Use enough water to reach the Sunbeam logo in the top
corner of the cup. Add a teaspoon of salt
to the cup and stir. Empty the salt solution
into the water reservoir in your iron. Allow the iron to stand
for 15 minutes, then empty out the water reservoir.Repeat this cycle with a
second cupful of salt water. Rinse out the reservoir
with clean water. You should perform this cleaning once a month.
