SOURCE: can someone tell me the values of the capacitors ?
EC18, EC19, EC20 are 1000uf/16v 105c
never had to replace EC9 and EC10 but should by the same value look at the size if the same as EC18 - EC20 I would go with the same value. It should be printed on the caps. If that did not fix your dead unit replace the power supply board and same time.
Check for the parts here:
http://www.mcmelectronics.com
# NOTE - If this info was helpful to anyone please click on yes!
SOURCE: ECS Green320 laptop , dead , no beep sounds good
Remove battery , attach ac power , turn on , if the laptop still has problems you've at least ruled out battery fault , sounds like faulty hardware somewhere alright but where??
SOURCE: Help... what is the problem with my main board ecs
there are 100's of possibilities, you need to give some more info, or just pop your windows disc in and see if you can repair
