Compatible Product Line Turntable Content 1 Flat Belt 6 Weeks to Asia 3 Weeks to the Canada USA Australia 1 Week to UK If you do not receive your item after
There's lot of sellers on E-Bay selling new belts have you tried there? Also Curry's Partmaster website. PS make a note of how it fits before you remove it. There's nothing worse than getting a new belt to fit when your not certain where it goes.
The specs for the RAM on this motherboard are: DDR400/333/266 SD RAM with ECC. Maximum you can use is 4Gb in total (so 1Gb stick in each slot would be fine - just make sure you match them in pairs). Maximum of 4GMaximum of 4GB of DDR400/333/266 SDRAM with ECCB of DDR400/333/266 SDRAM with ECC
the max RAM speed, type, make etc for your machine will be normaly be specified in the motherboard specs....if ur MB supports only 333mhz but if u add 400mhz speed RAM it may not work properly, check the MB mfg for the correct specs of the compatibility.
From the Asus spec site:
Memory
Memory Type
DDR SDRAM
Number of Memory Slots
4 x 184 Pin DIMMs
Supported RAM speeds
400 MHz • 333 MHz • 266 MHz
Max Supported RAM
4 GB
Memory
Memory Type
DDR SDRAM
4 x 184 Pin DIMMs
Max Supported RAM
4 GB
DDR SDRAM 400; 333; 266mhz
4 GB max 4x1024 184pin
Hope this helps.
here are the specs.
CPU FSB DDR DIMM Type Memory Frq.
800Mhz PC3200/PC2700/PC2100 400/333/266 Mhz
533Mhz PC2700/PC2100 333/266 Mhz
400Mhz PC2100 266 Mhz
the CPC and the moemories meets these spec. then you shouldn't have problem.
since you didn't spec the meories. I am assuming that the meories are within specs.
but, from what you say about, I suspect the memories is not up to part. looks like the meories are in PC 2100 range.
