This means that the batch file needs to be settled before more transactions can be made. Do a batch download and this should solve your problem. If you need more help call. Frank (775)338-6634
Some history for you---several years ago Hitachi began along with others to have issues with the optical light engines.
With a mix of high heat from a lamp into the engine (it has a blue,green and red section inside---guess what? BLUE is the first place that gets the heat and is damaged----minus blue and you have red and green which equals YELLOW.
Several of their sets made about 6 years ago (research 50v500) had exact same issues and were settled in a class action lawsuit.
The issue can but does not always affect the entire screen.
The question really is: This set really worth the part and labor cost for the repair?
On that earlier model I replaced under warranty over 40 of the engines. Also Sony and others have had similar issues some of which were settled in court.
Fuel filter could cause this issue. as pressure builds in the filter it forces settled dirt into the filter causing the stall. Then after it set for a few the dirt settles back down. Try replacing it. Its a cheap fix :)
If you catch the error right after you run it, do a void rather than a credit. A credit could takes weeks to show up for a customer and they won't be happy with you.
There's a known issue with this set due to defective rgb tubes... See this forum: http://www.hometheaterforum.com/htf/display-devices-tvs-projectors/105633-50-000-sony- hdtvs-may-recalled.html
