Please provide the faucet model number and possibly more detail e.g. removed handle but can't extract cartridge.
FYI, visit Eurostream http://www.eurostream.ca/tech_specs.asp and you can enter the model number for your faucet. There are installation guides, illustrations, part lists, etc.
SOURCE: Moen kitchen faucet model 7430 leak
cartridge does not stop that type of leak. If it is leaking from around the base of the spout it is o-rings that are the problem that are onthe valve after you pull the spout all the way off.
SOURCE: leaky eurostream kitchen faucet
if its leaking under the handle, all you need to do is remove the blue and red cap on the handle under you will find a 1/8 allen screw, loosen screw and remove handle and tighten the brass nut a little which will seat the packing underneath.
