Chek if you have power by the on of button , if tere is power , chek transformer , if there is power on both sides , if motor have a capacitor , test it don,t get shocked ,u can test it with a meter , or it must be abel to make a spark, look for lose wires , chek if tere is belds on the motor and the drum ,chec if the pully on the motor axes is not lose , that the motor run but not the drum ,chec the power lead and the male plug that go to the wall , find the book let in dex for ansers lastly phone your electrical persone , but don ,t get shoked ! please hope it helped
SOURCE: changing the brushes when the motor is off
Remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
SOURCE: BOSCH 1200 EXPRESS CLASSIXX ALL RINSE SPEED
bunged up theres a new word does that mean that you took off the pump and cleaned out the hoses as well as the pump yet the lights are still flashing on your unit please message me back with your answer and any further questions you may have thanks again Rick
p.s this also would mean you have cleaned the drain hose line that goes from the pump to the outside of the machine and tested the line to assure that water is flowing out of the drain line in a steady stream of water I await your reply Rick
SOURCE: bought bosch aquatak 100 pressure
Contact Bosch directly, they have been very helpful in the past.
Robert Bosch (Australia) Pty Ltd
1555 Centre Road
Clayton, VIC 3168
Phone: (03) 9541 5555
Fax: (03) 9543 5485
