Question about Masonry Tools
How do I remove blades from model 685A 6 1/8 inch jointer
Toolkraft jointer blade removal?
    Top Expert:
  • 30,497 Answers
6ya staff
SOURCE:
Gregg Rene
  • 86 Answers
SOURCE: I have inherited an older
Go to the bottom of the page of this link, under "Product Details", the manual is a PDF:
http://www.amazon.com/708457K-JJ-6CSX-Horsepower-Jointer-230-Volt/dp/B00006ANS5
Posted on Mar 01, 2009
efs_perpends
efs_perpends
  • 1996 Answers
SOURCE: Looking for blades for a 6 inch craftsman
Most reliable sharpening services will be able to grind knives for your jointer that will work just fine. The key is to match the existing knives as far as thickness (guage) and height of the new knives. You want them to give you maximum life but not extend too far past the cutterhead when adjusted all the way down. I don't know about your machine, but on an 8" powermatic the tip of the knife shouldn't extend more than about .0012" above the circumference of the cutterhead. You can check this with a set of calipers and give the height to the sharpener, then just choose high speed steel or carbide and you're on your way.
If you check the overall length of the knives, sometimes they are slightly under the nominal length, and a 6" long knife could bump into the housing as the cutterhead rotates, so this is one other thing to check before you go ahead and order them 6" long.
But the short answer is, no problem. Just get a reliable sharpener to make them for you, buy a quality steel blank, and have him put a fine grit polish or hone on the knives when he sharpens them...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 23, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: i need to find blades to fit a delta 6
go to Dewaltservicenet.com and under the service locator on the right hand side type in your information. The blade set number that I came up with is 37-658 and they show that as qty 3 in one package.
Posted on Mar 19, 2010
krab
SOURCE: blade guard for Atlas 6'' jointer
I can send you pics of the one I made from plywood for this same jointer. If you're looking for an original I can't help you there.
Posted on Sep 26, 2010
Anonymous
SOURCE: where can I get new
Click on the link below to order a replacement set of 12" blades for your Ryobi AH115
http://www.amazon.com/PLANER-BLADE-SET-AH115-RYOBI/dp/B000P8QN8U
Posted on Jan 10, 2011
Delta jointer, where do i find the wrench to loosen the nuts for the blade
go to Dewaltservicenet.com and with your model number you can download a schematic for this tool and also order the parts online. I tried finding them but there are too many jointers listed in the Delta category.
Apr 16, 2011 | Delta Jointer Blades 6 Inch Fits , Jet...
Eg2175need manual for craftsman 6inch jointer model number 113 20 680
Go to partsdirect.com and type in your model number. From there, you can order whatever you need for your jointer.
Feb 06, 2011 | Delta Jointer Blades 6 Inch Fits , Jet...
I need to find blades to fit a delta 6" X5 jointer, model 37-866x
Mar 19, 2010 | Delta Jointer Blades 6 Inch Fits , Jet...
Blade guard for Atlas 6'' jointer
Mar 09, 2010 | Masonry Tools
Infeed Table leveling
Well, the infeed table is supposed to be lower than the outfeed table. This is how the jointer actually removes material to flatten a face or board edge. What is important is that the the outfeed table is level with the top of the cutterhead blades, so as you push material through the cutterhead, the outfeed table fully supports the workpiece.
The infeed table is supposed to be adjustable up and down to remove different amounts of material.
If both infeed and outfeed tables were aligned, no material would be cut (assuming the outfeed was aligned with top of the blades).
Feb 28, 2009 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Need to find out haw to adjust cutter head and blades.
I called Jet and they e-mailed me a pdf file with the older manual. There is a toll free number on their website.
Jan 26, 2009 | Delta Jointer Blades 6 Inch Fits , Jet...
Technical
a jointer includes infeed and outfeed tables. A set of rotating blades is positioned between these two blades. A fence is set on one side of the jointer to serve as a guide. The infeed table and outfeed table are adjusted so that they are parallel, but the infeed table is slightly lower thereby exposing a small amount of the cutting blades. The woodworker then presses the lumber against the infeed table and pushes it onto the outfeed table; the rapidly spinning blades remove a small amount of material. If the wood is particularly warped, several passes on the jointer may be required.
Aug 27, 2008 | Delta 37-108 Push Blocks for Jointers
Masonry Tools Logo
114 people viewed this question
Top Masonry Tools Experts
Tom Chichester
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Masonry Tool Expert? Answer questions, earn points and help others
