Question about DCS Ovens
HELLO , I HAVE A 30 INCH DCS OVEN SELF CLEANING DOOR WILL NOT UNLOCK AFTER 5 HOURS AND IT NEVER GOT HOT , WILL NOT OPEN AND ITS MAKING NOISE . ANY HELP PLEASE ?
  • Tawnyel Jun 22, 2019
    My oven was accidentally put on clean and immediately turned off by my daughter. The door is still locked even when off. I have a nonstick liner in there and cannot run it. Help.
    Scholar:
  • 61 Answers
Hi Steve, from what you're describing,it sounds like you've got a bad door lock motor. It should have 2 check switches on the assembly. If one or both of those switches are bad,the control will not read the lock as being engaged so it will not allow the cleaning cycle to start. To get the oven door open you need to pull the locking hook over to the right with a coat hanger. To access the lock assembly you have to get under the top. It's a pain in the rear end but it is doable. Hope that helps and good luck.
Posted on Apr 03, 2019
6ya staff
SOURCE:
Anonymous
  • 35 Answers
SOURCE: Oven door locked
you would have to remove oven.remove top panel and disengage latch assembly if you are a tech.
Posted on Jun 25, 2007
premtech
William Rayburn
  • 934 Answers
SOURCE: self cleaning oven
Pheo,
Turn Breaker/Fuse for the stove, your electrical panel, “OFF” and then “ON”, wait 20 - 30 seconds and the door should unlock.
It may be that the temp sensor is going out and you'll need to have that looked at soon.
Bill
Posted on Nov 21, 2007
Anonymous
  • 6 Answers
SOURCE: oven door locked
First check to see if you activated the "child lock-out". See your manual to deactivate.
You could also try unplugging the unit, or trip the circuit breaker in your home which supplies power to the oven. Wait 5 minutes and turn power back on. This will reset the controls.
Posted on Jan 26, 2008
reg501
Richard
  • 413 Answers
SOURCE: cant unlock self clean oven door
Door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method.
Posted on May 29, 2008
Joe Hogan
  • 10865 Answers
SOURCE: self-cleaning oven door won't open
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Posted on May 20, 2009
Self cleaning oven
Pheo,
Bill
Nov 21, 2007 | Whirlpool GBD307PDS Electric Double Oven
H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
Hello.
Please apply the solution this way!
To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
Thanks for using fixya.
Sep 07, 2011 | Dacor Ovens
My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    We used the self cleaning option and now we cannot get the oven door open. The lever is stuck in lock mode. Can you give suggestion?
    Thank you and thanks for using fixya
    Sep 29, 2010 | Jenn-Air JGW8130A Electric Single Oven
    How do I cancel the self cleaning feature on my oven. Engaged the cleaning feature with the oven door open.
    Hello,Normally every body gets this almost right by cutting the power but there is a trick to this it can be done in 2 different ways depending on the unit
    First unplug the unit and wait 15 -30 seconds then plug it back in and wait for 15 to 30 seconds then unplug it again and repeat this step 1 more time then upon the final plug in wait for 5 min and then unlock as you normally would.
    now on the newer units the trick is to let it stand unplugged for 1 hour to allow the internal reset device to reset the appliance then plug it back in and then wait 5 min and you should hear it automatically unlock the appliance or you cn simply unlock it as you normally would
    BUT REMEMBER DO NOT TOUCH IT FOR THE 5 MINUTES AFTER THE PLUG IN STAGE OR YOU WILL HAVE TO DO IT ALL OVER AGAIN OK
    Thanks
    May 24, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    The lock will not release after cleaning
    This is GE's trouble shooting advise:
    Range - Oven Door Won't Unlock After Self Clean
    The Oven Door has been Locked Accidentally:
    • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
    • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
    • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
    • Note: Do not force the latch at anytime!
    Door Will Not Unlock After Cleaning:
    On models with mechanical latches:
    • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
    Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
    If the above suggestions do not work try the following to unlock your door:
    1. Disconnect power to range for 30 seconds.
    2. Reconnect power and see if door will unlatch.
    3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
    4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
    5. Wait approximately 30 minutes and try to unlock the door.
    6. If the door unlocks, the control has reset itself and there should not be any other problems.
    7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
    Note: Under no circumstances should you ever force the door or latch open.
    May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
    My stove won't unlock
    there may be a problem with the door switch try pushing in the door a little bit.also hold the clear off key for 3 to 5 seconds this should allow you to open the door.
    Jan 30, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Oven shut down during self clean. Door won't open
    Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
    Also check out this tip...
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Aug 21, 2009 | DCS (WOTD-227) Double Oven
    Frigidare Self Clean Oven
    I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
    1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
    2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
    3. PRESS THE "COOK TIME" BUTTON
    4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
    5. PRESS "START" BUTTON
    6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
    7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
    Sep 30, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Ovens Logo
    132 people viewed this question
    Top DCS Ovens Experts
    Jimmy
    NOEL
    NOEL
    Are you a DCS Oven Expert? Answer questions, earn points and help others
