SOURCE: Replaced the defrost heater but does not seem to working correctl
check the fan above the freezer coils (evaporator fan) and the defrost thermostat (located on the top of the coils), some fans won't run intill the defrost t'stat cools.
SOURCE: Evaporator freezing up, refer side.
There is a blanket type of heater stuck on the wall behind the coils. However, my tech guy checked the heater in our fridge, and he said it was ok. The problem seems to be that the sensors and main circuit board do not turn the heater on - this is an inherent design flaw, and may not be able to be fixed. There are 100 complaints about this this on consumeraffairs.com (usa), and tons more in England. This a very large problem which Samsung does not want to address, probably because of cost. I'm seriously thinking about taking them to small claims court.
SOURCE: evaporator coil freezes-up. thermister
Refrigerator
or Freezer not Cooling or Getting Cold
All units have some type of defrost...
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
heatman101
SOURCE: Will not Defrost, the
It's hard to tell from the diagrams I could find but if the heater is intertwined in the evaporator you do have to replace the evaporator.
