SOURCE: CELL PHONE NOT CHARGING
If your phone won't charge via your computer using a USB cable or via your pickup via a car charger, will it charger via the regular travel charger (i.e., plugged into the wall)? If it won't charge that way either, then the issue is with the connection or with the battery. If you replace the battery and it still doesn't charge, then the problem is with the connection. If this is the issue, then I would suggest replacing your phone, especially if it is 2 years or older. If it is a new phone and under 12 months old, then I would suggest getting a warranty replacement from your provider. If it is older, and you don't want to replace it, then try gettin a new battery, however, if it still doesn't charge, then like I said previously, it is the connection and it would be less expensive to replace the phone then to repair the connection. Hope this helps and let me know if you need any additional information.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
SOURCE: MY I9 cell phone doesn't wanna to charge
I had this problem. I replaced the provided wall usb charger. (I kept the cable and replaced the device you plug in the wall, you can get it as an ipod accesory in most stores.)
SOURCE: My nokia 5610 is displaying local mode but then not switching on!
download and install NSS (Nemesis service suite) here is the link.
http://www.b-phreaks.co.uk/index.php?main_page=page_2
1. click the manifying icon on the top right
2. click PHONE INFO
3. click SCAN (it should be in the middle)
4. and then in the power box. you will see 3 option (local, test, normal)
5. check NORMAL and click on change
6. now your phone turn on by itself..
7. GOODLUCK!..
SOURCE: bad contact charger
The charging port is bad, so you have to take it to a technician or get a universal or desktop charger to charge you battery.
