SOURCE: Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
SOURCE: I bought DMP-BD80 blu ray player.
make sure the line is good
if so the machine has a faulty network connection
which happens from time to time
SOURCE: Sony KP-53XBR300 Proj TV to Panasonic DMP-BD80 display problem
No, my problem is not solved. I thought I'd get 7 days free with no conditions whatsoever attached as your introductory screen wrongly suggests; and not have to sign-up for your service even on a trial basis, which I'm not interested in doing at this time. I'd rather not subscibe to such a service that utilizes these kind of 'bait-and-switch' tatics; it really suggests a very unbusiness-like, non-genuine service. Almost the lowest of the lows. Thanks, anyways.
SOURCE: cannot get panasonic dmp-bd65
Check the operating instructions for each device and connect accordingly. Click here to download the Panasonic DMP-BD67 pdf instructions manual . Update your device firmware ,
Check this link for D-Link Routers Support .
SOURCE: I have a DMP-BD55 blu
The DMP-BD55 does not support a wireless internet option. However, you can connect it to a wired port on your router (or a wired switch that connects to your router).
The manual for the DMP-BD55 is available here: http://service.us.panasonic.com/OPERMANPDF/DMPBD35-MUL.PDF .
I hope this helps.
