SOURCE: service life has ended on my epson stylus r320 photo printer
1.Turn off the printer.
2. Press the maintenance and the stop button simultaneously.
3.Turn on the printer again while holding the maintenance and the sop button.
this will reset the printer.
Thanks for your selflessness Steve H. describing the RESET procedure for the Epson R300 by simutaneouly depressing the POWER, STOP and MAINTENANCE switches.
I checked with Epson, via telephone, and they recommended going to an authorized dealer for ink pad replacement (approximately $100) or buy a new printer ( $150 - $250).
After completing your suggested RESET procedure successfully - I went a step further and mopped up the excess ink that was evident on the 'black ink pad' which was saturated with black ink. I used Kleenex which seemed to mop up the excess BLACK ink nicely, and continued this mopping procedure until there was no evidence of black ink on the Kleenex. There was very little evidence of spilled ink on the color pads.
Time alone will tell. So thanks again Steve - you saved me $100 to $200.
Oh yeah! I LOVE this printer.
SOURCE: Epson Stylus Photo R320
Turn off the power and look inside the machine to the right hand side. Just in front to f the print head you will see a white plastic dowel (see photo). Use something technical - like a finger, pen or screwdriver - to push this dowel in. You can then move the print head by hand to the middle of the carriage.
Once moved, turn the printer on and watch it travel back to the home position. If after returning home the dowel pops back out and does not retract itself, you will need to strip the machine out and rebuild the ASF section. Sounds hard but its just a few plastic parts to take apart and reassemble whilst looking to see if anything is broken.
Get a service manual; for the machine HERE if you need to strip it out.
SOURCE: Epson Stylus Photo R200 and R320 Status monitor in Vista
I was able to install the original XP status monitor from the CD, onto Windows Vista Home Premium.
On the install cd, you need to open the 'STM3' folder under whatever language you are installing, 'English' in my case. There are several .exe files in that folder:
E_S1LAC2.EXE
E_SCHK02.EXE
E_SIINS2.EXE
E_SPSU02.EXE
STMSETUP.EXE
For each of these, right click on the file, and choose 'Properties'. Under the 'Compaitbility' tab, choose 'Run this program in compatibility mode for:' - Windows XP (Service Pack 2).
Then run the 'STMSETUP.EXE' file, and it should install properly, and work. Although I cannot guarantee that it will work on your system, or that it will not have any negative effects on your computer.
So far, I have not had any trouble with it.
For the Epson R200 here's how I got it to work with Vista Business 32bit ...
#1 Disable AV software
#2 Open the CD for the printer software
#3 Find the launcher, right-click it and select Properties, then select the Compatibility tab
#4 Choose XP SP2 compatibility mode and Run As Administrator, then click OK.
#5 Double-click the launcher to start the program, select Custom then
then choose only the Driver and Status Monitor applications.
Worked for me, hopefully will do too for you. :o)
