SOURCE: How do I set the time and date on the phone and change voice mail
You must be on the main phone on jack 01 to set time. You can determine if your phone is jack 01 by pressing PROGRAM 99 on a display phone and then pushing the number 6 on the dial pad. The phone will read the jack and extension number. When you have determined the jack 01 phone, do the following: Press PROGRAM * * 1234(Default password is 1234. yours may have been changed) Press SP-PHONE 2 Times. To change the year enter the two digit year. If it is correct press FWD/DND to move the flashing indicator. MONTH is changed by pressing the AUTO ANSWER /MUTE key. DAY is entered as 1 or 2 digit day. DAY OF THE WEEK is entered by pressing the AUTO ANSWER/MUTE key. Press STORE to save your changes. Press SP-PHONE Enter 2 digit hour (Hour is flashing). Press FWD/DND button(Minute starts flashing). Enter 2-digit minute(Minute is flashing). Auto Dial/Store Button New time is stored. Lift handset and hang up to leave programming mode
SOURCE: Changing Voice Mail Password from the TOSHIBA DKT2010-SD set
you will need to download the manuall you should be able to get it off this sight hope this is some help
SOURCE: Delete old voice mail - program new voice mail
You can usually access the system voice mail setup from any extension.
Press Speaker
Dial ext 200.
When asked for security code, dial *,2,# (dial it twice if there is no code).
When main greeting begins, dial 632.
Using the soft keys under the display, press MORE, then MGR, then CHBX or, follow voice prompts if non-display phone.
Follow voice prompts. Remember, 1=Yes, 2=No.
SOURCE: How do I set up my voice mail on my Polycom IP 330 Phone?
Voice mail is probably a feature provided by your service provider.
I have a PBX with several different viop phones configured.
The voice mail is stored on the PBX you just need to configure the message waiting light on the phone and possibly a speed button that automatically dials the voice mail code.
I assume that you don't have a PBX and an internet service provider / voice service provider has those features available for you. They should have the documentation you need to configure the phone. If they specifically support your model phone you are in luck. Otherwise you will have to adapt from their generic description.
I have noticed that some really cheap voice plans don't include voice mail.
Hope this helps.
SOURCE: How to turn off voice mail on A V3 RZR phone
try dialing *780, you should hear beep beep beep confirming that it is turned off. press *78 to reactivate.
